Reduced Battery Capacity Due to Size
A project log for Booze
Booze is a tiny beacon similar to tile in concept but the firmware is customizable and has a rechargeable lipo battery(60mAH).
boozebooze 06/27/2019 at 10:000 Comments
I will be reducing the battery capacity to 60mAH from 75mAH because or the size. The 60mAH battery with dimensions 3mmx10mmx25mm will allow more components to be squeezed into the pcb.
Rich text editor
