Computer build from first principals
Complete computer build from the logic to the compiler and operating system.
Public Chat
3.1k views
I'm currently working on building a complete computer from the logic up. I will be implementing it 3 ways with bread boards, in Logisim and on an emulator.
Stage 1) Boolean Logic & Arithmetic
Stage 2) Sequential Logic
Stage 3) Machine Language and Computer Architecture
Stage 4) Assembler
Stage 5) Stack Arithmetic, Program Control and high level language design.
Stage 6) Compiler syntax analysis and code generation.
Stage 7) Operating system.
Multiplexer 8 way 16bit
JPEG Image - 29.96 kB - 06/25/2019 at 08:46
Preview
Demultiplexer 8 way
JPEG Image - 13.30 kB - 06/25/2019 at 08:46
Preview
XOR. Nand implementation.
Portable Network Graphics (PNG) - 7.94 kB - 06/25/2019 at 08:47
Preview
Multiplexer Nand implementation.
JPEG Image - 21.94 kB - 06/25/2019 at 08:47
Preview
Demultiplexer Nand implementation.
JPEG Image - 21.69 kB - 06/25/2019 at 08:48
Preview
View all 6 files
  • 1 × ALU 16 Function Arithmetic Logic Unit.
  • ALU Implemented
    Michael Walker06/26/2019 at 06:10 0 comments
     * The ALU (Arithmetic Logic Unit).
     * Computes one of the following functions:
     * x+y, x-y, y-x, 0, 1, -1, x, y, -x, -y, !x, !y,
     * x+1, y+1, x-1, y-1, x&y, x|y on two 16-bit inputs,
     * according to 6 input bits denoted zx,nx,zy,ny,f,no.
     * In addition, the ALU computes two 1-bit outputs:
     * if the ALU output == 0, zr is set to 1; otherwise zr is set to 0;
     * if the ALU output < 0, ng is set to 1; otherwise ng is set to 0.
    // Implementation: the ALU logic manipulates the x and y inputs
    // and operates on the resulting values, as follows:
    // if (zx == 1) set x = 0        // 16-bit constant
    // if (nx == 1) set x = !x       // bitwise not
    // if (zy == 1) set y = 0        // 16-bit constant
    // if (ny == 1) set y = !y       // bitwise not
    // if (f == 1)  set out = x + y  // integer 2's complement addition
    // if (f == 0)  set out = x & y  // bitwise and
    // if (no == 1) set out = !out   // bitwise not
    // if (out == 0) set zr = 1
    // if (out < 0) set ng = 1
    CHIP ALU {
        IN
            x[16], y[16],  // 16-bit inputs
            zx, // zero the x input?
            nx, // negate the x input?
            zy, // zero the y input?
            ny, // negate the y input?
            f,  // compute out = x + y (if 1) or x & y (if 0)
            no; // negate the out output?
        OUT
            out[16], // 16-bit output
            zr, // 1 if (out == 0), 0 otherwise
            ng; // 1 if (out < 0),  0 otherwise
        PARTS:
        // zx
        And16(a=x, b=false, out=zxTrue);
        Mux16(a=x, b=zxTrue, sel=zx, out=zerox);
        // nx
        Not16(in=zerox, out=notx);
        Mux16(a=zerox, b=notx, sel=nx, out=negx);
        // zy
        And16(a=y, b=false, out=zyTrue);
        Mux16(a=y, b=zyTrue, sel=zy, out=zeroy);
        // ny
        Not16(in=zeroy, out=noty);
        Mux16(a=zeroy, b=noty, sel=ny, out=negy);
        // f
        And16(a=negx, b=negy, out=andfxy);
        Add16(a=negx, b=negy, out=addfxy);
        Mux16(a=andfxy, b=addfxy, sel=f, out=fxy);
        // no
        Not16(in=fxy, out=notfxy);
        Mux16(a=fxy, b=notfxy, sel=no, out=out);
  • 16 Bit +1 Increment implementation. + HDL
    Michael Walker06/26/2019 at 00:13 0 comments
     * 16-bit incrementer:
     * out = in + 1 (arithmetic addition)
    CHIP Inc16 {
        IN in[16];
        OUT out[16];
        PARTS:
        HalfAdder(a=in[0],  b=true, sum=out[0],  carry=c0);
        HalfAdder(a=in[1],  b=c0,   sum=out[1],  carry=c1);
        HalfAdder(a=in[2],  b=c1,   sum=out[2],  carry=c2);
        HalfAdder(a=in[3],  b=c2,   sum=out[3],  carry=c3);
        HalfAdder(a=in[4],  b=c3,   sum=out[4],  carry=c4);
        HalfAdder(a=in[5],  b=c4,   sum=out[5],  carry=c5);
        HalfAdder(a=in[6],  b=c5,   sum=out[6],  carry=c6);
        HalfAdder(a=in[7],  b=c6,   sum=out[7],  carry=c7);
        HalfAdder(a=in[8],  b=c7,   sum=out[8],  carry=c8);
        HalfAdder(a=in[9],  b=c8,   sum=out[9],  carry=c9);
        HalfAdder(a=in[10], b=c9,   sum=out[10], carry=c10);
        HalfAdder(a=in[11], b=c10,  sum=out[11], carry=c11);
        HalfAdder(a=in[12], b=c11,  sum=out[12], carry=c12);
        HalfAdder(a=in[13], b=c12,  sum=out[13], carry=c13);
        HalfAdder(a=in[14], b=c13,  sum=out[14], carry=c14);
        HalfAdder(a=in[15], b=c14,  sum=out[15], carry=false);
  • HDL Completed for Boolean Logic.
    Michael Walker06/25/2019 at 09:21 0 comments
    Finished the HDL code for the logic, starting work on the ALU.
View all 3 project logs
  • 1
    Boolean Logic HDL
     * 16-bit bitwise And:
     * for i = 0..15: out[i] = (a[i] and b[i])
    CHIP And16 {
        IN a[16], b[16];
        OUT out[16];
        PARTS:
        And (a=a[0], b=b[0], out=out[0]);
        And (a=a[1], b=b[1], out=out[1]);
        And (a=a[2], b=b[2], out=out[2]);
        And (a=a[3], b=b[3], out=out[3]);
        And (a=a[4], b=b[4], out=out[4]);
        And (a=a[5], b=b[5], out=out[5]);
        And (a=a[6], b=b[6], out=out[6]);
        And (a=a[7], b=b[7], out=out[7]);
        And (a=a[8], b=b[8], out=out[8]);
        And (a=a[9], b=b[9], out=out[9]);
        And (a=a[10], b=b[10], out=out[10]);
        And (a=a[11], b=b[11], out=out[11]);
        And (a=a[12], b=b[12], out=out[12]);
        And (a=a[13], b=b[13], out=out[13]);
        And (a=a[14], b=b[14], out=out[14]);
        And (a=a[15], b=b[15], out=out[15]);
     * And gate:
     * out = 1 if (a == 1 and b == 1)
     *       0 otherwise
    CHIP And {
        IN a, b;
        OUT out;
        PARTS:
        Nand(a=a, b=b, out=aNandb);
        Nand(a=aNandb, b=aNandb, out=out);
     * 4-way demultiplexor:
     * {a, b, c, d} = {in, 0, 0, 0} if sel == 00
     *                {0, in, 0, 0} if sel == 01
     *                {0, 0, in, 0} if sel == 10
     *                {0, 0, 0, in} if sel == 11
    CHIP DMux4Way {
        IN in, sel[2];
        OUT a, b, c, d;
        PARTS:
        DMux(in=in, sel=sel[1], a=inZero, b=inOne);
        DMux(in=inZero, sel=sel[0], a=a, b=b);
        DMux(in=inOne, sel=sel[0], a=c, b=d);
     * 8-way demultiplexor:
     * {a, b, c, d, e, f, g, h} = {in, 0, 0, 0, 0, 0, 0, 0} if sel == 000
     *                            {0, in, 0, 0, 0, 0, 0, 0} if sel == 001
     *                            etc.
     *                            {0, 0, 0, 0, 0, 0, 0, in} if sel == 111
    CHIP DMux8Way {
        IN in, sel[3];
        OUT a, b, c, d, e, f, g, h;
        PARTS:
        DMux(in=in, sel=sel[2], a=inZero, b=inOne);
        DMux4Way(in=inZero, sel=sel[0..1], a=a, b=b, c=c, d=d);
        DMux4Way(in=inOne, sel=sel[0..1], a=e, b=f, c=g, d=h);
     * Demultiplexor:
     * {a, b} = {in, 0} if sel == 0
     *          {0, in} if sel == 1
    CHIP DMux {
        IN in, sel;
        OUT a, b;
        PARTS:
        Nand(a=sel, b=sel, out=notSel);
        Nand(a=notSel, b=in, out=notSelNandb);
        Nand(a=notSelNandb, b=notSelNandb, out=a);
        Nand(a=in, b=sel, out=inAndSel);
        Nand(a=inAndSel, b=inAndSel, out=b);
     * 16-bit multiplexor:
     * for i = 0..15 out[i] = a[i] if sel == 0
     *                        b[i] if sel == 1
    CHIP Mux16 {
        IN a[16], b[16], sel;
        OUT out[16];
        PARTS:
        Mux (a=a[0], b=b[0], sel=sel, out=out[0]);
        Mux (a=a[1], b=b[1], sel=sel, out=out[1]);
        Mux (a=a[2], b=b[2], sel=sel, out=out[2]);
        Mux (a=a[3], b=b[3], sel=sel, out=out[3]);
        Mux (a=a[4], b=b[4], sel=sel, out=out[4]);
        Mux (a=a[5], b=b[5], sel=sel, out=out[5]);
        Mux (a=a[6], b=b[6], sel=sel, out=out[6]);
        Mux (a=a[7], b=b[7], sel=sel, out=out[7]);
        Mux (a=a[8], b=b[8], sel=sel, out=out[8]);
        Mux (a=a[9], b=b[9], sel=sel, out=out[9]);
        Mux (a=a[10], b=b[10], sel=sel, out=out[10]);
        Mux (a=a[11], b=b[11], sel=sel, out=out[11]);
        Mux (a=a[12], b=b[12], sel=sel, out=out[12]);
        Mux (a=a[13], b=b[13], sel=sel, out=out[13]);
        Mux (a=a[14], b=b[14], sel=sel, out=out[14]);
        Mux (a=a[15], b=b[15], sel=sel, out=out[15]);
     * 4-way 16-bit multiplexor:
     * out = a if sel == 00
     *       b if sel == 01
     *       c if sel == 10
     *       d if sel == 11
    CHIP Mux4Way16 {
        IN a[16], b[16], c[16], d[16], sel[2];
        OUT out[16];
        PARTS:
        Mux16(a=a, b=b, sel=sel[0], out=aMuxbSel);
        Mux16(a=c, b=d, sel=sel[0], out=cMuxdSel);
        Mux16(a=aMuxbSel, b=cMuxdSel, sel=sel[1], out=out);
     * 8-way 16-bit multiplexor:
     * out = a if sel == 000
     *       b if sel == 001
     *       etc.
     *       h if sel == 111
    CHIP Mux8Way16 {
           e[16], f[16], g[16], h[16],
           sel[3];
        OUT out[16];
        PARTS:
        Mux4Way16(a=a, b=b, c=c, d=d, sel=sel[0..1], out=abcd);
        Mux4Way16(a=e, b=f, c=g, d=h, sel=sel[0..1], out=efgh);
        Mux16(a=abcd, b=efgh, sel=sel[2], out=out);
     * Multiplexor:
     *       b otherwise
    CHIP Mux {
        IN a, b, sel;
        OUT out;
        PARTS:
        Nand(a=a, b=notSel, out=aNotSel);
        Nand(a=b, b=sel, out=aNandb);
        Nand(a=aNotSel, b=aNandb, out=out);
     * 16-bit Not:
     * for i=0..15: out[i] = not in[i]
    CHIP Not16 {
        IN in[16];
        OUT out[16];
        PARTS:
        Not (in=in[0], out=out[0]);
        Not (in=in[1], out=out[1]);
        Not (in=in[2], out=out[2]);
        Not (in=in[3], out=out[3]);
        Not (in=in[4], out=out[4]);
        Not (in=in[5], out=out[5]);
        Not (in=in[6], out=out[6]);
        Not (in=in[7], out=out[7]);
        Not (in=in[8], out=out[8]);
        Not (in=in[9], out=out[9]);
        Not (in=in[10], out=out[10]);
        Not (in=in[11], out=out[11]);
        Not (in=in[12], out=out[12]);
        Not (in=in[13], out=out[13]);
        Not (in=in[14], out=out[14]);
        Not (in=in[15], out=out[15]);
     * Not gate:
     * out = not in
    CHIP Not {
        IN in;
        OUT out;
        PARTS:
        Nand(a=in, b=in, out=out);
     * 16-bit bitwise Or:
     * for i = 0..15 out[i] = (a[i] or b[i])
    CHIP Or16 {
        IN a[16], b[16];
        OUT out[16];
        PARTS:
        Or (a=a[0], b=b[0], out=out[0]);
        Or (a=a[1], b=b[1], out=out[1]);
        Or (a=a[2], b=b[2], out=out[2]);
        Or (a=a[3], b=b[3], out=out[3]);
        Or (a=a[4], b=b[4], out=out[4]);
        Or (a=a[5], b=b[5], out=out[5]);
        Or (a=a[6], b=b[6], out=out[6]);
        Or (a=a[7], b=b[7], out=out[7]);
        Or (a=a[8], b=b[8], out=out[8]);
        Or (a=a[9], b=b[9], out=out[9]);
        Or (a=a[10], b=b[10], out=out[10]);
        Or (a=a[11], b=b[11], out=out[11]);
        Or (a=a[12], b=b[12], out=out[12]);
        Or (a=a[13], b=b[13], out=out[13]);
        Or (a=a[14], b=b[14], out=out[14]);
        Or (a=a[15], b=b[15], out=out[15]);
     * 8-way Or:
     * out = (in[0] or in[1] or ... or in[7])
    CHIP Or8Way {
        IN in[8];
        OUT out;
        PARTS:
        Or (a=in[0], b=in[1], out=out1);
        Or (a=in[2], b=in[3], out=out2);
        Or (a=in[4], b=in[5], out=out3);
        Or (a=in[6], b=in[7], out=out4);
        Or (a=out1, b=out2, out=outa);
        Or (a=out3, b=out4, out=outb);
        Or (a=outa, b=outb, out=out);
     * Or gate:
     * out = 1 if (a == 1 or b == 1)
     *       0 otherwise
    CHIP Or {
        IN a, b;
        OUT out;
        PARTS:
        Nand(a=a, b=a, out=nota);
        Nand(a=b, b=b, out=notb);
        Nand(a=nota, b=notb, out=out);
     * Exclusive-or gate:
     * out = not (a == b)
    CHIP Xor {
        IN a, b;
        OUT out;
        PARTS:
        Nand(a=a, b=aNandb, out=aNandNotb);
        Nand(a=aNandb, b=b, out=notaNandb);
        Nand(a=aNandNotb, b=notaNandb, out=out);
  • 2
    Arithmetic HDL for ALU.
     * Adds two 16-bit values.
     * The most significant carry bit is ignored.
    CHIP Add16 {
        IN a[16], b[16];
        OUT out[16];
        PARTS:
        HalfAdder(a=a[0], b=b[0], sum=out[0], carry=carry0);
        FullAdder(a=a[1], b=b[1], c=carry0, sum=out[1], carry=carry1);
        FullAdder(a=a[2], b=b[2], c=carry1, sum=out[2], carry=carry2);
        FullAdder(a=a[3], b=b[3], c=carry2, sum=out[3], carry=carry3);
        FullAdder(a=a[4], b=b[4], c=carry3, sum=out[4], carry=carry4);
        FullAdder(a=a[5], b=b[5], c=carry4, sum=out[5], carry=carry5);
        FullAdder(a=a[6], b=b[6], c=carry5, sum=out[6], carry=carry6);
        FullAdder(a=a[7], b=b[7], c=carry6, sum=out[7], carry=carry7);
        FullAdder(a=a[8], b=b[8], c=carry7, sum=out[8], carry=carry8);
        FullAdder(a=a[9], b=b[9], c=carry8, sum=out[9], carry=carry9);
        FullAdder(a=a[10], b=b[10], c=carry9, sum=out[10], carry=carry10);
        FullAdder(a=a[11], b=b[11], c=carry10, sum=out[11], carry=carry11);
        FullAdder(a=a[12], b=b[12], c=carry11, sum=out[12], carry=carry12);
        FullAdder(a=a[13], b=b[13], c=carry12, sum=out[13], carry=carry13);
        FullAdder(a=a[14], b=b[14], c=carry13, sum=out[14], carry=carry14);
        FullAdder(a=a[15], b=b[15], c=carry14, sum=out[15], carry=carry15);
     * Computes the sum of three bits.
    CHIP FullAdder {
        IN a, b, c;  // 1-bit inputs
        OUT sum,     // Right bit of a + b + c
            carry;   // Left bit of a + b + c
        PARTS:
        HalfAdder(a=a, b=b, sum=sumab, carry=coutab);
        HalfAdder(a=c, b=sumab, sum=sum, carry=coutcab);
        Or(a=coutab, b=coutcab, out=carry);
     * Computes the sum of two bits.
    CHIP HalfAdder {
        IN a, b;    // 1-bit inputs
        PARTS:
        Xor(a=a, b=b, out=sum);
        And(a=a, b=b, out=carry);
    CHIP Inc16 {
        IN in[16];
        OUT out[16];
        PARTS:
  • 3
    The ALU
    CHIP ALU {
        IN
        OUT
        PARTS:
        // zx
        // nx
        // zy
        // ny
        // f
        // no
View all 3 instructions
Xpan Victor wrote 10/11/2023 at 20:17 point
Really nice, currently hacking on it as well. Using the book
Michael Walker wrote 08/11/2019 at 04:32 point
Absolutely was! Such a great project / book / video series.  These guys are amazing educators.
DocInfinity wrote 08/06/2019 at 01:22 point
inspired(?) by Shimon Schocken and Noam Nisan‘s nand2tetris project?
