ALU Implemented
06/26/2019 at 06:10 • 0 comments/** * The ALU (Arithmetic Logic Unit). * Computes one of the following functions: * x+y, x-y, y-x, 0, 1, -1, x, y, -x, -y, !x, !y, * x+1, y+1, x-1, y-1, x&y, x|y on two 16-bit inputs, * according to 6 input bits denoted zx,nx,zy,ny,f,no. * In addition, the ALU computes two 1-bit outputs: * if the ALU output == 0, zr is set to 1; otherwise zr is set to 0; * if the ALU output < 0, ng is set to 1; otherwise ng is set to 0. */ // Implementation: the ALU logic manipulates the x and y inputs // and operates on the resulting values, as follows: // if (zx == 1) set x = 0 // 16-bit constant // if (nx == 1) set x = !x // bitwise not // if (zy == 1) set y = 0 // 16-bit constant // if (ny == 1) set y = !y // bitwise not // if (f == 1) set out = x + y // integer 2's complement addition // if (f == 0) set out = x & y // bitwise and // if (no == 1) set out = !out // bitwise not // if (out == 0) set zr = 1 // if (out < 0) set ng = 1 CHIP ALU { IN x[16], y[16], // 16-bit inputs zx, // zero the x input? nx, // negate the x input? zy, // zero the y input? ny, // negate the y input? f, // compute out = x + y (if 1) or x & y (if 0) no; // negate the out output? OUT out[16], // 16-bit output zr, // 1 if (out == 0), 0 otherwise ng; // 1 if (out < 0), 0 otherwise PARTS: // zx And16(a=x, b=false, out=zxTrue); Mux16(a=x, b=zxTrue, sel=zx, out=zerox); // nx Not16(in=zerox, out=notx); Mux16(a=zerox, b=notx, sel=nx, out=negx); // zy And16(a=y, b=false, out=zyTrue); Mux16(a=y, b=zyTrue, sel=zy, out=zeroy); // ny Not16(in=zeroy, out=noty); Mux16(a=zeroy, b=noty, sel=ny, out=negy); // f And16(a=negx, b=negy, out=andfxy); Add16(a=negx, b=negy, out=addfxy); Mux16(a=andfxy, b=addfxy, sel=f, out=fxy); // no Not16(in=fxy, out=notfxy); Mux16(a=fxy, b=notfxy, sel=no, out=out); }
16 Bit +1 Increment implementation. + HDL
06/26/2019 at 00:13 • 0 comments/** * 16-bit incrementer: * out = in + 1 (arithmetic addition) */ CHIP Inc16 { IN in[16]; OUT out[16]; PARTS: HalfAdder(a=in[0], b=true, sum=out[0], carry=c0); HalfAdder(a=in[1], b=c0, sum=out[1], carry=c1); HalfAdder(a=in[2], b=c1, sum=out[2], carry=c2); HalfAdder(a=in[3], b=c2, sum=out[3], carry=c3); HalfAdder(a=in[4], b=c3, sum=out[4], carry=c4); HalfAdder(a=in[5], b=c4, sum=out[5], carry=c5); HalfAdder(a=in[6], b=c5, sum=out[6], carry=c6); HalfAdder(a=in[7], b=c6, sum=out[7], carry=c7); HalfAdder(a=in[8], b=c7, sum=out[8], carry=c8); HalfAdder(a=in[9], b=c8, sum=out[9], carry=c9); HalfAdder(a=in[10], b=c9, sum=out[10], carry=c10); HalfAdder(a=in[11], b=c10, sum=out[11], carry=c11); HalfAdder(a=in[12], b=c11, sum=out[12], carry=c12); HalfAdder(a=in[13], b=c12, sum=out[13], carry=c13); HalfAdder(a=in[14], b=c13, sum=out[14], carry=c14); HalfAdder(a=in[15], b=c14, sum=out[15], carry=false); }
HDL Completed for Boolean Logic.
06/25/2019 at 09:21 • 0 commentsFinished the HDL code for the logic, starting work on the ALU.
