1Prepare components
- Temperature sensor (DHT22)
- Servo motor (SG 90)
- Arduino Uno
- CP 2102 Module
- Transistor 2N 2222
- 1k ohm resistor
- 180 ohm resistor
- LED
- Wires
- Female holders
- Pins
- Stripboard
2Prototyping on breadboard
3Build your Arduino shield
4Testing
Use a heat source that is above 30 degrees celsius to test if there is an output at servo and LED.
5Draw your best impression of an animated character !
6Assembly
7Give yourself a pat on the back! Well done! You have made your very own hydration reminder!
Juin
