A new home for your Atomic Pi (based on a Raspberry Pi enclosure from another project: https://hackaday.io/project/160052-voicebox).
OpenSCAD scripts to print a customizable enclosure for the Atomic Pi single board computer.
Atomic.scadMain script to generate the case components.scad - 10.27 kB - 06/29/2019 at 23:41 |
AtomicBoard.scadScript to generate a dummy Atomic Pi board for visualization.scad - 2.10 kB - 06/29/2019 at 23:41 |
Utilities.scadPositioning utilities, etc.scad - 4.56 kB - 06/29/2019 at 23:41 |
Cone.stlStandard Tesselated Geometry - 975.31 kB - 06/29/2019 at 23:41 |
Grill.stlStandard Tesselated Geometry - 310.54 kB - 06/29/2019 at 23:41 |
The first step before fixing the parameters of your Atomic Pi enclosure is to find a way to power it. The mini board by Digital Loggers is a pain to fit into a box, so I made my own board from a RadioShack(?) prototype board and some spare headers.
The +5V and GND headers to the right are to power the cooling fan. I'm using a 50mm 12V DC fan from my junk box. It seems to run fine on +5V. The blue headers are power in: +12V, GND, GND, +5V.
(I'm not using a +12V supply as it's easier to just plug a USB sound card into an external USB hub.)
I only wired up the most easily accessible GPIO pins (from bottom right, GPIO2/0/5/3), and skipped the serial pins as the board was getting too messy. (If I ever need more than 4 GPIOs I'll add some wires.)
Any prototype board will do, as long as it has 13 rows of holes (if you want to breakout the full 26 pin header.)
I joined because of this project with the atomic pi. i want to build a power supply and case like these soon
