Redesigning
07/14/2019 at 13:44 • 0 commentsI was looking at the files for the russian AR-600 and i noticed i can implement the motor upward from the joint to make it more light and versatile. currently in the process of soldering all components.
Testing The Motor + arrival of aluminium 4040
07/08/2019 at 08:05 • 0 commentsToday, I tested the motors and the code a bit, the aluminum 4040 has arrived and its pretty heavy to put on a robot.
More designing
07/01/2019 at 03:14 • 0 commentsAbout a month has passed since I started this project personally. I have went through 3 design iterations but having seen the modular and universal design of the Slate Robotics TR2 I hope to redesign it and make it easy to build and assembly with easy to find and repeatable parts.
Damn it, lost the v4 design gotta do it again
JoeCat1207
