SakuraDoll
Sakura Doll is designed to start your SMD soldering adventure beautifully.
Starting from
has orders / reviews
Ships from
Sakura Doll is a cute pin. Its size is about 28mm wide by 54mm long. It has the details of cherry blossom, that is called Sakura in Japanese too. It uses the dual-inverter chip NL27WZ04 to blink one red LED behind the top flower, with ENIG finish. It is fully documented at https://github.com/nwmaker/sakuradoll.
Gerben wrote 07/09/2019 at 13:12 • point
Looks really cute. Nice job.
