New Version V2.9
03/01/2022 at 06:47 • 0 commentsWhat's new in V2.9:
1, Stand alone: As normal main board that run Marlin firmware on the stm32 32bit MCU,without RaspberryPi;
2, Add CAN transceivers and CAN connector, support CAN bus extruder PANDA_CAN board![]()
PandaPi V2.8 /Support Klipper
03/08/2021 at 08:02 • 0 commentsWhat's new in V2.8:
- Support Klipper printing;
- Support Running marlin firmware in MCU like normal control board,but there is no SD slot,so can not do SD printing in this mode.
- Support resin printing;
- Integrated DC-DC power module;
64 bit RT kernel
01/07/2021 at 13:11 • 0 commentsI successfully ported the new 64-bit RT kernel, latest octopi, to the 1G/2G/8G raspberry Pi4b. and did some test
the new Image for PI4 1/2/8GB with latest octopi and RT arm64 kernel. welcome to test. BTW, the samba shared folder server was installed by default. login name and password are "pi" and "raspberry"
https://drive.google.com/file/d/12SVpaWUfYfMcyAgHXftomMzmOi_RGhgE/view?usp=sharing
Change the temperature sensor to PT100
11/01/2020 at 12:57 • 0 comments![]()
Easy mode for Marlin configure
07/03/2020 at 11:03 • 0 comments![]()
Source Syntax Highlighting
06/28/2020 at 15:04 • 0 commentsHi all, the new web editor has feature of Source Syntax Highlighting just click update Raspbian for that.
3D files of Pandapi
06/06/2020 at 14:10 • 0 comments![]()
Ready for shipment
05/03/2020 at 05:35 • 0 comments![]()
The new v2.5,only one for test
04/26/2020 at 15:35 • 0 comments -
Run marlin in real time mode
04/14/2020 at 10:59 • 0 comments![]()
mark
