TouchUI printing
04/10/2020 at 09:38 • 0 comments -
New released IMG file
04/06/2020 at 03:11 • 0 commentsthe new IMG file PandaPiX_20200405.zip have been uploaded to MEGA. https://mega.nz/#F!qJgHzRwB!Sl6hKYqNDLAtKXnzekdB3A
Calibrate the motor native speed;open the runaway code;new web marlin edit tool;
higher the marlin priority in OS;
fix U drive auto mount bug;
PandaPi Marlin2.0.4.4 release
03/25/2020 at 16:16 • 0 commentsPandaPi Marlin2.0.4.4 release img for pi3/pi4
zero solder for add inductive autobed level sensor
02/25/2020 at 10:34 • 0 commentsintegrate the optocoupler to PandaPi, that support 6V~36V inductive sensor, about $2
Plug in temperature humidity sensor DTH11 to Octoprint
02/08/2020 at 08:20 • 0 comments -
marlin2.0 test version is online
12/28/2019 at 11:52 • 0 commentsmarlin2.0 test version is online,have done a few test.
Next hardware version with 6 drivers
12/26/2019 at 08:25 • 0 commentsgot the sample of the next hardware version today. compare to V1.0, this hardware has 6 motors drivers; 2 hotends;TMC2208/2209 UART interface;sensorless homing without extra wiring; this V2 is just a sample and will be available at more than one month later. and the software also need to be debugg and test for double extruders.
portinng Marlin2.0
12/26/2019 at 08:22 • 0 commentsI am portinng Marlin2.0
5 pandas send out ! good luck.
11/30/2019 at 05:04 • 0 comments5 pandas send out ! good luck.
