PRUSA ADD-ON
The ultimate add-on for your prusa MK3(S)
Ever wanted to expand your MK3 with octoprint, this is the ultimate add-on with almost no additional space!
Top.stl
A better TOP.stl (the old one was not straight enough)
Standard Tesselated Geometry - 30.36 kB - 07/13/2019 at 22:42
Download
PRUSAEXPAND.zip
STEP and STL files
Zip Archive - 165.28 kB - 07/13/2019 at 12:12
Download
  • Build instructions
    dannyvandenheuvel07/14/2019 at 12:26 0 comments
    These are al the parts you need.
    You have to buy a raspberry pi 3 without 40 pin connector or must cut all pins.
    At first add raspberry pi with short bolts 3mm onto the bottom plate.
    (don't forget to cut the pins (I did it afterwards)
    You have to add the two supports first and place the lcd board, after that you can screw the bottom plate onto it.
    Finally plug in the power mini usb and at the top (I screwed it with 2 screws afterwards)
    >This is the final result, I'm very happy with it!
View project log
