- Pre-milled top-hat rail housing with 9 modules (Made in Germany)
- Top shell with transparent or gray front panel
- 40-pin socket connector (for plugging in the Pi)
- 40-pin male connector (for plugging in a HAT)
- 10 screw terminals with 5 mm pitch for free use
- perfboard area forn own circuits
- Separate screw terminal for power supply
- Pre-assembled circuit board - no soldering necessary
- Hole grid area for wired components
- Connection socket for OLED display
- All connections of the Raspberry Pi are routed to labeled terminal strips
- Integrated switching regulator 5V/4A (input voltage 9 - 35V DC)
- Power supply also possible via micro USB of the Pi
- Installation option for active cooler
- suitable for Raspberry Pi models 4 and 5
