DB25 Pinout:
Control CNC via parallel port with GRBL
DB25 Pinout:
GRBL_to_JP-382A.pdfSchematicAdobe Portable Document Format - 76.26 kB - 07/22/2019 at 08:25 |
GRBL_to_JP-382A.zipGerber Filesx-zip-compressed - 75.19 kB - 07/22/2019 at 08:25 |
Does this even work? Your schematic doesn't have a crystal for the CH340G, and datasheet says its required. And I'm guessing you just use GRBL firmware?
Yes, it works. CH340C doesn't need an external crystal. Yes, it uses GRBL, it's in the name "GRBL to Parallel Port".
Hey, just on hackaday.io. Gerber files are on here to download though.
question, where can I get the firmware for atmega?
