This is a dummy load. This device developed to test your power sources, battery, supply circuit, power bank etc. You can set constant current level with built-in potentiometer or analog input voltage. You can read actual current value with multimeter or Arduino like development board. Only read analog voltage and convert to current with our examples on github.
You can directly access Arduino examples on SLB github page. No wait to test!
Features and Specifications
The best price/performance!
Up to 3 A constant current.*
Easy to use. You can use it as soon as you get the product.
Robust and stable.
Arduino or other development boards friendly! You can use it together, more powerful. Examples available on github.
Smallest area for dummy loads. Only one square inch PCB!
it is a good idea, but how i know if my battery is dead ?
