I've added the monitor support to the model v3 and you can see that there will be a need for external structure to support the sheeting around and also some serious thought needed if this is going to be a hideaway desk.
Also some careful measurements to see what amount of protrusion is needed in front and behind the servers to manage the cables etc and cover them nicely with a door.
I'm also concerned regarding overall stability.
Joni
