Pumpkin_Control_3.py
The lates script for running the Pumpkin, with NeoPixel back lighting.
text/x-python-script -
24.79 kB -
07/19/2019 at 03:23
Download
ws2812.py
Debugged NeoPixel library that will work with the OpenMVM7.
x-python-script -
4.92 kB -
07/19/2019 at 03:22
Download
Pumpkin_Control_2.py
This is the basic script for running the Pumpkin.
22.80 kB -
07/19/2019 at 02:59
Download
Assembly Mount.stl
This mount has four pockets for 1/4" Dia X 1/8" Thick magnets (K&J P/N ZD42E) to hold the entire eye assembly in place.
Standard Tesselated Geometry -
1.17 MB -
07/19/2019 at 02:02
Download
Servo Bracket.stl
Mount for two SG51R type servos; one for traverse and one for elevation. This press fits into the Assembly Mount.
75.08 kB -
07/19/2019 at 02:02
Download
Ball Bracket.stl
This is the part and gets solvent bonded with the front half of the Hobby Lobby Plastic Eyeballs.
961.21 kB -
07/19/2019 at 02:02
Download
Link Gage.stl
This is the gage for cutting & bending the push-pull rods to size.
126.64 kB -
07/19/2019 at 02:08
Download
Link Assembly Fixture.stl
This gage is used to position the push-pull rods while connecting them to the Ball Bracket. The triangular portions are to support it during printing and are intended to be broken away before use. It nestles over the socket ball and the notches in the Ball Bracket to fully align the rods.
31.72 kB -
07/19/2019 at 02:08
Download
Hole Knife Holder.stl
This, along with a 1/4" drill,I used to hold a small craft knife blade to cut the eye holes in the pumpkin.
23.52 kB -
07/19/2019 at 02:13
Download
Alighnment Plug.stl
This part, along with the Alignment Clamp, is used to form the warm Shapelock into the eye mount. It also has four pockets for 1/4" Dia X 1/8" Thick magnets (K&J P/N ZD42E). An extra 4 magnets are attached to the back of the flange before use, so these extra magnets get embedded in the Shapelock during the forming process.
I recommend this part be printed in ABS and vapor polished so there is less for the Shapelock top stick to. I then recommend you coat this, and the Alignment Clamp, with a couple of coats of Smooth-on Ease Release™ 2831 before use too.
100.08 kB -
07/19/2019 at 02:13
Download
Alignment Clamp.stl
This part, along with the Alignment Plug, is used to form the warm Shapelock into the eye mount. It is used to hold the small diameter endow the plug flush to the outside of the pumpkin, so all the eyes are at a consistent depth.
I recommend this part be printed in ABS and vapor polished so there is less for the Shapelock top stick to. I then recommend you coat this, and the Alignment Plug, with a couple of coats of Smooth-on Ease Release™ 2831 before use too.
50.47 kB -
07/19/2019 at 02:13
Download
Camera Mockup.stl
I mounted this to a piece of perf board to approximate the OpenMV camera. The bore of it is intended to accept the rod I used to measure heightsand pointing angle for the camera.
301.64 kB -
07/19/2019 at 02:26
Download
Measurement Plug.stl
This plug is designed to mount in the finished eye holes and its bore is intended to accept the same the rod I used to measure heights and pointing angles for each eye. It also has four pockets for 1/4" Dia X 1/8" Thick magnets (K&J P/N ZD42E), so it will stay in the same place as the eye assembly.
112.58 kB -
07/19/2019 at 02:26
Download
