1Assemble Electronics
Follow the diagram below to connect the EzSBC ESP32_ANT-01, Logic Level Converter, Thermal Printer and Power.
<image coming>
<better instructions coming>
23D Print Enclosure
Using your preferred method (yourself, a friend or online service), print the enclosure (available in GitHub hardware folder). Clean up support material.
<image coming>
3Assemble
Slide breadboard in to enclosure, glue in switched power jack and power converter. Slide in and fasten thermal printer. Connect power and communication to all devices.
<image coming>
4Create Google Apps Script
Go to Google Apps Script and create a new script. Copy the script from GitHub and update the calendar name. Save. Deploy the script and authorise access to the calendar.
5Clone, Modify, Upload Firmware
Clone the firmware from GitHub. Ensure you have PlatformIO as this is needed for compiling and uploading to the ESP32. Modify the WiFi credentials and Google Apps Script URL to that given when the Script was deployed.
6Print Useless Calendar Receipt
<image coming>
lokthelok
