1Build instructions
Download full build instruction - http://bit.ly/2TKfQjP
2Programming the Dial
I have written a comprehensive Arduino library for the dial, with enough examples to help you quickly get started.
You can also write and share your own.
All required libraries.
- https://github.com/ahmsville/Ahmsville-Dial
- https://github.com/ahmsville/Magnetic_rotary_encoding
- https://github.com/ahmsville/Advanced_capacitive_touch_detection
- https://github.com/arduino-libraries/CapacitiveSensor/zipball/master
- https://github.com/FastLED/FastLED
Sample code:
#include <Ahmsville_dial.h> #include <FastLED.h> /* upload sketch to the dial to test all its functions. ....By Ahmsville... */ Ahmsville_dial ahmsville_dial = Ahmsville_dial(); //create a new ahmsville dial instance /********************************************************************LED CONFIGURATION*****************************************************/ #define DATA_PIN 10 #define LED_TYPE WS2811 #define COLOR_ORDER GRB #define NUM_LEDS 4 CRGB leds[NUM_LEDS]; #define BRIGHTNESS 127 uint8_t gHue = 0; // rotating "base color" int count = 0, touch; void setup() { ahmsville_dial.initialize_ahmsvilleDial(1); //initialize ahmsville dial initializeLED(); } void loop() { rainbow(); // LED animation count += ahmsville_dial.knob(); //detecting knob rotations (returns a signed integer in relation to the direction of the rotation) touch = ahmsville_dial.capTouch(); //detecting capacitive touch (returns integer 1 - 4 or 0 when no touch is detected) Serial.print(count); //print knob rotation count Serial.print("\t"); if (touch == 1) { //print "singletap" if touch type is 1 Serial.println("singletap"); delay(1000); } else if (touch == 2) { //print "doubletap" if touch type is 2 Serial.println("doubletap"); delay(1000); } else if (touch == 3) { //print "shortpress" if touch type is 3 Serial.println("shortpress"); delay(1000); } else if (touch == 4) { //print "longpress" if touch type is 4 Serial.println("longpress"); delay(1000); } else if (touch == 0) { //print "no input" if touch type is 0 Serial.println("No input"); } ahmsville_dial.normalize(1); } /********************************************************************LED SETTINGS/ANIMATION*************************************************/ void initializeLED() { // tell FastLED about the LED strip configuration FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip); // set master brightness control FastLED.setBrightness(BRIGHTNESS); } void rainbow() { EVERY_N_MILLISECONDS( 20 ) { //frames/milliseconds delay // FastLED's built-in rainbow generator fill_rainbow( leds, NUM_LEDS, gHue, 10); // send the 'leds' array out to the actual LED strip FastLED.show(); } EVERY_N_MILLISECONDS( 30 ) { gHue++; // slowly cycle the "base color" through the rainbow } }
Ahmed Oyenuga
