1 to 1.6 Vdc led blinker
Hello,
I am sorry, made a mistake, it's not shelved.
It works perfectly, one 1,4v garbage battery lasts several months.
Yes that is a good name, but I use Carbono instead in order to complement the use of Silício. In English Carbon.Silicon
Than you for your comments.
Actually germanium follows in that column of the periodic table so that would be the next name to add. 😁
Lignum.Germanium
Why a shelved project? Doesn't it work? Looks good anyway.
Given your commendable love of wood maybe you should add lignum to your name. 😁
Yes, delete it Cancel
You are about to report the project "Led blinker", please tell us the reason.
Hello,
