We are currently using cotton belts that were made by a dressmaker. Unfortunately it's impossible to single handedly fasten them because they lack the proper mechanism. They are also not elastic with makes the problem even worse.
One of the biggest challenge will be to figure out a way for proper mounting, without the exoarm slipping down or rotating when it shouldn't.
