Multitool 3D Printer - Blackbox
Blackbox shifts 3D printing towards a multitool manufacturing robot.
FDM printing is not just one of the slowest 3D printing processes; it also lacks accuracy and requires support structures. But in some aspects, they can still exceed High-end printing processes. While industrial processes can produce accurate parts consistently, they struggle when it comes to material diversity. And that's when FDM shines. You can print almost any thermoplastics like PLA, ABS, TPU, Nylon, PEEK and even Polyimide. But the best part about it, these Materials can be combined. Multitool printing enables entirely new ways to design and fabricate things previously rendered impossible.
Note that most of the Information on this page is outdated. You´ll find all necesary resources and information here:
Discord https://discord.gg/5vVm5r9cSw
Assembly Guide https://blackbox.dozuki.com/
Kits and Spares https://kb-3d.com/store/en/
Download + Manual
Discord
Why
I believe that multi-material 3D printing will be the next big step. Not so much for 3D printing, but the fabrication of highly integrated mechanism. Robots still require a great deal of assembly, which makes them expensive. With multi-material manufacturing, it is possible to fabricate print in place mechanism with several materials which need little to no assembly. There are not many printers out there, which offers a platform robust enough for this task. The most common commercial multi-material printer Ultimaker, Sigmax, and E3D only provide Bowden fed extruder, which are barely capable of processing flexibles.
Soft robot proof of concept
How
With a tool changing platform trimmed for multi-material printing and material freedom. This is achieved by the unique passive water cooling and coupling system which provides up to six direct driven extruder. The motor is shared among all tools which is why standard electronics can be used. It also offers numerous possibilities to use the extruder motor for different tools with additional axes or various types of toolheads like Paste, Syringe, Fibre or Silicone.
Goal
Offering a convenient BOM and producing the custom parts to make this printer replicable. Custom parts are the X-Plate, tool cooler, and coupling lock. We are currently in talks with different supplier to deliver these parts at an attractive price point. From that point, we can add specialized tools and finally experiment and explore what's possible to fabricate with such a multi material beast.
Blackbox complete with 6 direct drive tools
Blackbox Multi Tool X-Axis, highly integrated and completely watercooled.
Direct drive tool coupled to the X-Axis
Toolbank with parking tools
X-Carriage and direct tool prototype
Soft robot gripper printed out of TPU and PLA in one process
Features
  • Up to 6 direct driven tools
  • Passive Water cooling
  • High-Speed Z-Axis for 3D movement
  • True RepRap, most custom parts are printed
  • Built with Off-the-shelf Parts
  • Readily accessible
  • Adaptable for specialization (especially medical applications)
  • Air cooling is possible as an affordable alternative
Technical Data
  • Prinsize: 300x300x275, fully usable with any tool
  • CoreXY Kinematics
  • T-Slot Frame
  • MGN 12 Linear Rails
  • Belted Z-Axis
  • 9mm GT2 Belts
  • Tailored for Duet3D Board
  • Z-Axis Overhaul Done!
    Marc Schömann • 09/29/2019 at 14:54 • 0 comments
    The Z-Axis seems to be the easiest one of the three axes. But I had quite some trouble implementing three linear rails inside the Blackbox nicely. I had a version with four linear rails before, but although it looks very clean, such a overconstrain is not something I like too much. The Problem was that with a linear rail in the center facing towards the bed would take up too much space which would result in significantly less build volume. The solution was to rotate the linear rail towards the front, that way the supporting profile can be placed underneath the frame.
    Belt Tensioner and linear carriage bracket and block and tackle fixture in one part.
    Pulley idler bracket with integrated block and tackle guide wheel.
    Dual linear Rails on the other side
  • Printed Igus Gears Arrived!
    Marc Schömann • 09/29/2019 at 13:21 • 0 comments
    The Self aligning gear which I ordered threw Igus arrived and look great, despite the thin wall warnings. Unlike the original Bondtech gears which feature straight tooth, these are actually shaped according to 0.5 module standard. Therefore the characteristic clicking (ie Backlash) is almost completely gone.
    One problem which remains is the fixture on the steel rod. I planned to use heat inserts, but the material is so slippery that they just fall threw. So I glued the heat inserts into the gear. That worked but i don´t really like it, so I´m currently in contact with Igus about best practizes. So there will be a new version of custom gears as soon as I got more Info.
  • Renderings to fill in the waiting time
    Marc Schömann • 09/05/2019 at 14:49 • 0 comments
    The parts arrived Germany, but they did not arrive at my home yet, so I made some renderings to pass the time
    Toolbank with silicone wiper and leakblocker
    X-Axis with a docked tool
  • Ooze Blocker and Wipe Shield
    Marc Schömann • 09/04/2019 at 10:14 • 0 comments
    In the previous Iterations I faced some problems with oozing and leftover filament on the nozzles which often got dragged into the print. The solution was a combination of a silicone wiper and ooze blocker. The tool changing process was quite different before which is why I had to redesign this component.
    Old Oozeblocker and wipeshield in the previous iteration
    Silicone wiper (front) and the leak blocker at the back, closing the nozzle while the tool is parking.
    Toolbank with the parking tools
  • Self Aligning Mating Gears
    Marc Schömann • 09/02/2019 at 17:27 • 0 comments
    The new tool changer uses the Bondtech Extruders 1:3 reduction to decouple the extruder from its motor. To make this work, the gears need to be aligned at any time (which sounds easy but it's complicated with open-loop stepper motors).
    Another solution are rounded teeth which arrange themselves when they mate together. These gears are highly inspired by Lego gears (like Gear 12 & 24) which are beveled and often used for gear shifter models. I guess this method only works when one of the wheels is free, luckily that's the case when the extruder is heated up!
    These gears would be really expensive when they where made on a lathe. But Igus, a german specialist for non abrassive thermoplastics has a SLS process which produces accurate longliving gears similar priced like shapeways.
    I ordered them right away to test the tolerances and see if they are really self aligning, posting pictures as soon as they arrive!
  • Final Evaluation of the CNC Parts
    Marc Schömann • 08/30/2019 at 14:40 • 0 comments
    We are currently working on the latest modifications on the CNC parts to make them ready for Production.
    First step to finalize the design was an intereference analysis to see if everything is in place and nothing is blocking the tool from docking. It displayed some flawes which where easy to fix.
    Next step was prototyping the the Parts in PLA. It looks quite good but I can´t test a complete assembly yet because im still wating for parts...
    I even prototyped the Lock in PLA and surprisingly it works ok, good enough for prototyping. So I guess with a thicker bolt one could completely print the air cooled version without any special parts!
    In the final steps Max will perform a force calculation to display areas where material can be saved. I will continue adding other parts to the prototype making sure everything works.
  • How I designed the Blackbox
    Marc Schömann • 08/25/2019 at 21:12 • 0 comments
    As an Industrial designer, I probably got a different approach than other RepRap contributors, which are often mechanical or electrical engineers. With this log, I want to communicate how decisions are made from a designers perspective.
    Complexity and Material
    3D Printer are visually complex machines, and in my opinion, there is no reason to increase the complexity by unnecessary ornaments. Many printers are taking the extra effort in hollowing and sparing areas, often in an ornamental fashion. Many times the origin does not stem from functional aspects but our visual habits. Mass-produced, injection-molded products look like this. Injection-molded parts need to maintain a specified wall thickness, and its weight is purely dependent on the outer shape. And CNC milled objects are carved out of solid material, which adds a lot of weight when it's not hollowed. But 3D printer work different, FDM printed parts are almost hollow, and it's the perimeter and solid layer which adds most weight. Just think about it, three perimeter weight the same as three lines of infill, which can be several centimeters depending on the density. Therefore a cutout or excessive contour is not worth the effort in most cases. Sometimes structure can add stability (like the groves on a can), but it needs to be purposefully deployed.
    Unity
    Proximity is one of the gestalt principles, which are a fundament of design theory. The principle says that objects which are close together, share the same characteristics, and point in the same direction are forming visual groups. There is another design theory called "product language," which goes beyond that and imagines objects as subjects which speak a visual and tactile language. A group of buttons could say, "We control the same things, so we are close together." Braun did this masterfully in the 60s and 70s, the well-known calculators used the same buttons in a rectangular array, but four different colors are grouping the buttons in layers of interaction. I used this knowledge to create modules which appear as a unit inside the printer.
    Blocky Design
    When these thoughts are applied, the result is somewhat "blocky." It may look a bit plain, but it reduces visual complexity and makes adjustments and customizations very easy. The Fusion files are now open to everyone, and the hurdle for modifications should be low. The blocky design in combination with bevels is also a good indicator for the print orientation.
  • New Tool Changing System
    Marc Schömann • 08/24/2019 at 21:27 • 2 comments
    I'm very proud showing the new tool changing system. Mainly because many new ideas came directly from the community. The new system breaks with a lot from the previous version (which is why I have to redraw almost all outline representations), but this effort is well worth the trouble.
    X-Carriage
    The X-Carriage now carries only a motor and mainly consists of an aluminum plate. This plate is connecting the linear bearing with the motor and tool changer. The motor attached to the x-axis mates with the Bondtech style tool. That way, only one stepper is necessary for all the tools, which is a massive advantage over other tool changers. It´s similar to the Makerbot smart extruder system, where the tools can be removed from the motor. Bondtech is the perfect platform for this because it already decoupled the drive gear from the motor with it's 1:3 reduction. The motor gear might need some small changes in its geometry to make sure it docks smoothly.
    Docking System
    Besides the X-Carriage, Blackbox is now using a different docking system for accounting the additional tool weight and ensuring a trouble-free usage. I was using a magnetic system along with a bent wiper, which works well for small tools. But it always was a compromise to gain fast results. The next version will use a system first introduced by Joshua Vasquez. It utilizes a cable-driven mechanic, which I adopted almost wholly. This mechanism is a remote locking system, which allows using a big servo or stepper motor away from the moving axes. The only changes are the bearing arrangement (double-flanged bearing), and I will use shifter cable housing, which is self-lubricating and bendable.
    Direct driven tools
    The tools are essentially a shrunk-down Bondtech BMG extruder with additional kinematic coupling. A passive cooler cools the tool, but it can also be air-cooled! Yes, that's right, air cooling will significantly lower the entry hurdle to build this printer. But the best about it is that Blackbox can now utilize up to 6 direct driven tools, which means flexibles can be printed in any tool! The external motor also opens up a vast scope for other power tools, whether it be a syringe tool, a rotation axis, or additional z-axis.
    Toolbank & Parking System
    The tool bank is now cooled with a single 15x3mm aluminum strip which cools all tools together. The parkin system mostly stays the same; it's just arranged a little different because the extruder gets now picked up by the Y, not the X-axis as it was before. Apart from that the nozzle still gets wiped with a silicone sheet when it's picked up or off. When it's parking a small height adjustable silicone cube blocks any leakage.
    Waiting for Parts
    While I'm pretty confident that the rebuild will go well due to the great detail in the Fusion Files down to the screw, I'm currently waiting for crucial parts (Chrome steel balls and shafts, Fans, Linear Rails, Bondtech gears). But I already started prototyping the tools and x-axis with PLA.
    Summary
    Drawbacks
    More Custom Parts
    The new coupling mechanism uses more parts which need to be gathered and assembled. The lock bolt is an additional custom part.
    Advantages
    All direct driven tools
    The previews system with one direct and x Bowden driven tools was a compromise. Bowden can work, but they are annoying, especially in a tool changing scenario due to the additional leaking. Bowden extruder also limits the maximum speed when used with pressure advance systems.
    Easier Electronics
    It was necessary to use one of the few boards which support multiple extruder and lots of stepper driver to power several tools. Now only 5 Steppers are required to drive the whole system: one for XYZ each + one extruder...
  • Custom PCB for easier wiring
    Marc Schömann • 08/24/2019 at 16:17 • 0 comments
    Extruder PCB
    These little PCBs originate from the Cobot Project. At that time, we were planning to ease wiring by using some small adapter PCBs. They are based on the red micro match connector and the well known JST connectors. The idea is to connect all the different electronic parts on an extruder (Fan, Heater, Heatsensor, Endstops, Motor) to a board which adapts it to a ribbon cable. Ribbon cables do not require special crimping tools. They can be assembled using just a vice. These things are so practical that I'm still using them for the Blackbox project. Willy Blum created the PCBs, a talented electrical engineer and I'm currently planning to sell these together via known RepRap shops.
    The Heater in this PCB is also connected via a JST connector. This is not ideal ofc and will be one of the minor changes regarding the PCBs. I thought about a screw terminal, but it seems like a bad idea on a vibrating moving device.
    Hall Effect Sensor
    The other PCB is a two-channel hall effect endstop. It is reliable and can be daisy-chained to use two endstop with one four-wire ribbon cable (this two-channel). But the best about this sensor is it´s size, compared with other hall effect sensors used in the RepRap community this one is around half the size. While it´s designed to be used with a ribbon cable and the micro match connectors, there are three soldering pads for JST connectors to remain compatible.
    As always any input is appreciated!
  • Soft Robot Gripper
    Marc Schömann • 08/22/2019 at 10:58 • 3 comments
    Tri Gripper
    The next version of the soft robot actuators can grab things, and the tri gripper is even powerful enough to crawl! While the dual gripper is printed the same way as the waving hand, with a sliding rack and pinion, the tri gripper works a bit different. The cables are directly attached to the servo rolls the wires up. This rotating movement causes a lot of stress for the wires. Some adjustments to the roll-up attachment helped to reduce the stress, but the lifespan is still quite low.
    Tri gripper close up: cables are already damaged
    Dual Gripper
    The dual gripper works like a charm and is quite powerful. Thanks to the linear actuator, it´s a lot more durable than the tri gripper. But there could some enhancements made regarding the release angle and grip profile, especially regarding small round parts.
    What's next?
    Next challenge will be something that walks/crawls, I want to use as few motors as possible to achieve that, but im unsure how will work in the ende, so any inspiration or tip is very welcome! But for the next two weeks priority will be on the printer again, there are some great updates which i can´t wait to share!
View all 16 project logs
yveslouis wrote 01/14/2021 at 09:29 • point
Hello,
First, congratulations on your project: a maker dream is being born from your work.
I have several practical questions:
1) do you plan to open source your work, and for "less technical" people go for commercial distribution?
2) with you already avenues for additional alternative tools; all will not be able to go, a priori, with your head, or am I wrong?
3) How can we help you? If you are looking for beta testers / makers, do not hesitate!
Yves-Louis
Bonjour,
Tout d'abord félicitations pour votre projet : un rêve de maker est en train de naître de votre travail.
J'ai plusieurs questions pratiques :
1) comptez vous mettre en open source votre travail, et pour des personnes "moins techniques" allez vers une distribution commerciale ?
2) avec vous déjà des pistes pour des outils alternatifs complémentaires ; tous ne pourront aller, à priori, avec votre tête, ou je me trompe ?
3) comment pouvons nous vous aider ? Si vous recherchez des béta testeurs / makers, n'hésitez pas !
Yves-Louis
bcrawforddesign wrote 08/22/2020 at 20:19 • point
Awesome work! I'm working towards a tool changer as well, and you've provided a lot of inspiration. What are your thoughts on a tool changer in a dual extruder configuration? The second extruder (non tool changer head) could be dedicated to support material. I figured there may be a speed improvement in this setup.
César wrote 01/26/2020 at 20:19 • point
Amazing project! will follow and when I got enough money ill build one :D
william s wrote 09/26/2019 at 17:03 • point
This project looks very interesting! But sadly the link for the discord doesnt work for me. Is it removed?
Marc Schömann wrote 09/28/2019 at 22:44 • point
No not at all, but the discord link expires from time to time(although it is set to permanent) try this one: https://discord.gg/6ehrA34 we would love to welcome you!
Andrew Overby wrote 09/19/2019 at 18:04 • point
I've been following your first iteration of this project for a while now and I couldn't help but create an account so I could comment on a job well done! The single motor idea is amazing and I'm very impressed by the kinematic coupling setup (saw the article explaining it on your website). I also like the water-cooled system to help with higher-temperature materials. Can this system account for different tools and offsets if a different hotend is desired?
Marc Schömann wrote 09/26/2019 at 13:14 • point
Hey Andrew, thanks a lot for your kind words! Yes the offset of the tools is set in the firmware, i´m planning on integrating a small constantly mounted microscope to make calibration easier. A Octoprint plugin would be amazing for that, but there is no software developer in the team yet.
Joe Pomodoro wrote 09/05/2019 at 01:35 • point
@--marc  Very nice, clever use of the single extruder motor on the tool-changer carriage. What control board are you using? It seems most are using Duet or Klipper for tool changing machines. Also, you mentioned a fast-moving z-axis. Is the Z-axis leadscrew driven, belt driven?
Marc Schömann wrote 09/05/2019 at 10:16 • point
Thanks Joe! Im using a ultratronics board with klipper currently but the next iterations will be tailored towards duet. The Z-Axis is belt driven with a 1:25 belt reduction!
Andrey V wrote 09/02/2019 at 17:50 • point
I can't understand the idea. Yes, pics looks good, but what benefits this device has IRL?
Marc Schömann wrote 09/02/2019 at 18:37 • point
Six direct drive extruder which can be used in a single print process. Have a look at the youtube video to see the potential!
Andrey V wrote 09/03/2019 at 02:54 • point
If you are talking about multi-material printing, I think this idea was already realized around 10 years ago for industrial printers and more than a year ago for Prusa very clever way and with only one extruder.
https://youtu.be/E1ZxTCApLrs
Marc Schömann wrote 09/03/2019 at 11:04 • point
Im sure the Prusa engineers put a lot ofthoughts into this, but the system clearly has it´s flaws. It consists of many fragile components which need to be aligned perfectly to work and many user are facing problems. A tool changer on the other hand is almost self aligning and therefore more reliable.
The temperature is adjusted while printing the purge tower, but depending on the material combination that can cause problems. PVA, for example, undergoes pyrolysis at around 200°C, if you purge it with a material which requires higher temps it will certainly jam the extruder. Just look up the prints done with this approach, multi-material examples are very seldom, but you see tons of multicolor prints.
The Blackbox concept also allows using other tools than filament extruder like silicone, syringe, fiber, paste extruder or CNC tool head. The possiblities of a tool changing 3D printer are not limited to extruding filament and thats what I like about it!
Marc Schömann wrote 09/03/2019 at 08:17 • point
Industrial FDM Printer where only able to print two materials, mostly used for support structures. The Prusa ist not really multi material but multicolor like the palette.
Andrey V wrote 09/03/2019 at 09:26 • point
If I understand correctly, it is possible to use completely different materials(with the same printing technology) with Prusa multi-material addon.
ProJet MJP 5600 is able to print with 6 different materials.
Marc Schömann wrote 09/03/2019 at 09:56 • point
Shared nozzles limit temperature differences between the materials; also, such systems are prone to jam, the crazier the material combination the more likely it is to do so. This approach also requires a very big purge tower making the process even slower than tool changing.
Now the ProJet MJP 5600 utilizes an entirely different print process. They call the process "MultiJet Printing" but it's essentially what Stratasys does with their polyjet technology (which they bought from Polyjet). Instead of using filament it prints photocurable resins very different to thermoplastics we use. The flexible resins, for example, feel sticky, attract dust like a magnet and disintegrate after a few years. It's a true prototyping platform and despite that these printer cost 50k+.
Andrey V wrote 09/03/2019 at 10:12 • point
I think the temperature changing for each material is not a problem. I think Prusa engineers already done this. The problem with the materials mixing also solvable with the software and/or small mechanical upgrade (additional place for old material).
Victor Dedios wrote 09/01/2019 at 19:28 • point
Really cool project! It's great to see smart mechanical designs like this around here. In this DIY community, there are lots of good electronic projects but there is a need of more designers that can bring concepts to reality. There is a lot of creative work that can be done in mechanics!
I love the coupling system, I have a project about a PCB manufacturing platform and multi-tool changer is what is giving me more headaches, still a concept.
Keep up with the good work @Marc Schömann !
Marc Schömann wrote 09/02/2019 at 10:13 • point
Thanks a lot for your kind words! Yes especially industrial designer neglect the open source movement almost entirely. Even tough it makes design comprehensible (maybe it´s because of that). I like your PCB platform concept, would love to have something like this here!
RandyKC wrote 08/01/2019 at 20:13 • point
So glad to see this project entered!
Beautiful work. I’ve got to explore your choice of Fusion, but as considered as your design is I’m sure it was the right choice as well.
I’m going to see how your ideas could be adapted to work on a FABtotum I backed way back when. It has a horizontal carriage instead of a vertical. I hate to lose working area by putting it on either side of the carriage.
Marc Schömann wrote 08/02/2019 at 19:27 • point
Thanks a lot for your support! Fusion has two crucial advantages over all other CAD programs: It is accessible to everyone and allows cooperative working. I am very excited about how it will be to work with the community.
Pls update me if you plan to retrofit your FABtotum, would love to see it!
Carlos Echenique wrote 08/22/2019 at 19:10 • point
Is there a Linux version of Fusion 360?
izak.oliver wrote 07/31/2019 at 15:12 • point
Exceptional design! This printer will put the industry on its head! Great work Marc! It deserves top spot
Marc Schömann wrote 08/01/2019 at 18:23 • point
It´s so nice you are on board with this! Thanks a lot!
