Front
08/26/2017 at 15:54 • 0 comments -
Clock Start
08/26/2017 at 15:46 • 0 commentsThe following images show the lcd display on startup.
Installing the back panel
08/20/2017 at 18:35 • 0 commentsInstalling the back panel a fiddly job because it's a little cramped inside. The top row of buttons are (ltr) set/next, up, down and esc. the bottom row are daylight saving switch, time set potentiometer – because the clock works with UTC time you can adjust the time with the potentiometer to your local time – and the last switch on the row turns the full-moon light on or off.
Moon calibration and pre-assembly
08/20/2017 at 09:39 • 0 commentsStarted the calibration and pre assembly.
Note that there is still a protective film over the acrylic "glass".
Firmament
07/27/2017 at 09:06 • 0 commentsThe firmament of the clock will have a blue glitter finish over the matte-black paint giving it an illusion of stars.
The Panels etc.
07/27/2017 at 08:57 • 0 commentsAll the panels an parts have been primed and sanded ready for they're final coat of matte-black paint and to top it off a few coats of matte-clear sealer.
Testing the rotation
04/25/2017 at 06:14 • 0 commentsAnd now with light in the moon.
The Moon V2
04/05/2017 at 06:15 • 0 commentsBecause the moon will be lit from the inside light has to pass through the material and black isn't the right color for that. Also i had a problem with the black inserts being a little of center causing the moon to wobble. So i made these parts which let light pass through and can be adjusted later by loosening te bolts.
Not welded to the sphere yet.
The moon
04/04/2017 at 06:49 • 0 commentsCnc cut the pieces to support the moon and welded them to the sphere.
To drill the holes in the sphere in a perfect line I made a little jig. It's basically a circle with a piece of m3 threaded rod in the middle. First you screw in the rod below the surface. You align the drill press bit in the hole. Then you place the sphere in the circle and drill the first hole. After that you screw the rod out so it protrudes like in the photo below. You place the sphere with the previously drilled hole over the threaded rod and drill the next hole. Et voila perfectly aligning holes.
