1POST STROKE SPASTICITY REHAB HELPER
Bill of Materials
We use in the project the components
No
Q
Name
Description
1
2
Controller
Arduino nano R3
2
6
Tenzo Bridge
Pressure Sensor Scale Module
3
6
ADC fo Tenzo Bridge
HX-711
4
12
Servo mini SG90
Servo mini SG90 9g Tower Pro
5
0
Blue Tooth module
HC-05
6
6
Magnetic Snaps
3/4-inch size Magnetic Button Clasp Snaps
7
2
Shottky Diodes
Shottky Diodes 1N5817
8
2
3300 uF 16 V capacitor
Low ESR capacitor.
9
2
0.1 uF 16 V capacitor
Capacitor for high friequency noise damp.
10
3
Low base for servo
3D printed or milled plastic components
11
2
High base for servo
12
10
Servo mounted lever arm
13
6
Short node lever
14
4
Long node lever
15
2
Breadboard
Plastic Breadboard or other flat plastic
2Bill of Materials
We make some introduction about it.
- Controller Arduino Nano R3.x (992-ARD-NANO30NP) or any Arduino Nano R3.x compatible.
Servo SG90 9g Tower Pro. You can use any type of Servo. Please pay attention that some servos can have other control pulse parameters.
18mm (3/4-inch) size Magnetic Button Clasp Snaps![]()
Breadboard.We used plastic cutting board, but any flat surface can be used.
- Scale weight sensors 10 kG (or other)
3Schematics
Schematics consists of two parts - 12-servo controller and differential dynamometer. For connection can be used USB or BT interface.
4Mechanics
We use the simplest analogue servo. You can use any kind of servos. The bases, lever arms are shown in a figure:
5Breadboard and Blocks
We took plastic breadboard and install 6 blocks on it, for example it is left hand drawing, L – for the right hand.
The size of components are defined by the servo in use. We made all drawings for Servo mini SG90 9g Tower Pro. Here is one block
We use 3/4-inch size Magnetic Button Clasp Snaps. It is screwed with two node lever arms so it can be rotated.
Here You can see the breadboard with installed blocks and fully assembled
6Programming
Program code is Arduino IDE compatible. You can download code from git hab https://github.com/DrOnkel/ReHabJr or Hackaday project file section.
BuildInstruction2.pdf This instruction
DifDinLCD.ino Arduino code for Diffirential Dynamometer controller
Dinamometr_Schematics.jpg Add files via upload 6 days ago
ServoMotorsSchematics.jpg Add files via upload 6 days ago
ServoRehab01.ino Arduino code for servo controller, USB control version
ServoRehab_i_06.ino Arduino code for servo controller, BT control version
Download the program to Your Arduino Nano using Arduino IDE. You can download it from arduino.cc .
The movement is defined by arrays MassX[8][2]. It contains 8 main points of finger base path. The movement between main points is calculated using linear interpolation. The full review of program code is in Program instruction.
7External Box and Hand Holder
We construct 3d box for 3d printer. The box is bigger than 3d printer base and we devide the component by 2 or 3 parts. Here is 4 side parts of box
Here is top deck, we connect it to the sides of the box
We hold the parts together. We use plastic DIN- rail (1) and magne holders (2)
8Hand Holder
Part 2 contains magnet for attaching hand holder with magnets too
We install this plate with magnets into han holder
9It works
Sergei V. Bogdanov
