So yes, hopefully, the analog frontend is finally completed! Aside from minor modifications (like better opamps, not that shitty 741), the design has been completed. As you can see in the screenshot down here, eye position and blink are both recognizable. The last step is to process the signal in the Arduino. Eye position processing is quite easy, but blinking recognition will be a challenging quest.
![](https://cdn.hackaday.io/images/2868111565632996024.png)
