A theme with this project has been it's ever increasing complexity.
In the current design I'd decided 24 bits of instruction was enough to deal with, but this means that I need complex decoding logic in the control unit to multplex bits in the instruction into tghe various devices; a single bit might represent a bit of an address or a constant or an ALU operation depending on the instruction type.
Last night when updating the docs in the github project I made a comment about the horizontal encoding that I'd used in the absolutely initial design where I'd called this device "simple".
The comment I made in github was about horizontal encoding: "I quite like the idea that it would be rather like a hand cranked music box."
Horizontal encoding is similar to a mechanical music because of the triival control logic; the musical box has a trivial system of tuned prongs and a simple set of spikes on a programmed wheel that plucked those individual prongs.
Today, on the way back from a rare trip to the shops (Covid 19 etc) I was reflecting on the complexity of the control logic that I had. I did a quick mental; calculation of how many ROMs it would take if I went back to a stricter horizontal encoding with each control wire hooked to a specific output bit of a ROMs; no decoders nothing. To replace all that logic would take nine roms. Arguably, that is actually a fair trade off by introducing simplicity of for the sake of a few extra ROM's. Swapping a lot of little chips and wires for a few larger chip.s
By the time I'd gotten home, I'd gone on to calculate how many ROM's it would take to represent every control wire assuming I was to going to use nothing more than a single layer of decoders. This left me with 6 ROMS plus a few decoder chips.
I found myself realising that the home brew CPU designs that I've seen seem to be avoiding storing the instruction across multiple ROMS. I see 24 or 32 bit instructions out there but these tend to in a single ROM and loaded into instruction registers over a sequence of clock pulses to achieve the width.
I could do the same of course. I could use a single 27C40001 to hold all the data and load 6 instruction registers over 6 clock cycles. But, these ROM devices are slow so that approach would be slow and anyway I'd still end up with a similar amount of wiring hassle as using using a bunch of ROM's in parallel.
So I'm edging towards a rework where I either go with ROM-only horizontal approach using 8 or 9 ROMs, vs , a minimal decoding approach using just 6 ROMS.
... to be continued ....
