- It is colorful with nice vibrant primary colors
- There are already commercially available neon lights which I could borrow the design from (and not have to come up with it myself)
- Finally, it is just a plain cool logo
After a quick google search I found a nice image of the original neon sign which I saved and imported into inkscape for editing.
In solidworks, with the dxf imported as a series of dots (image above) I set it as a construction sketch (yellow inner lines) and began drawing offset lines around the desired shape to form the footprint of the frame (blue lines). I connected all these lines to make a shape with holes where there would be no EL wire to save filament and shorten printing time. From this base shape I extruded upwards to form the 3D shape.
