I love the look of neon signs but they aren't particularly easy to DIY without glassblowing skills and equipment, so EL Wire to the rescue!
Thanks to UTSOURCE for sponsoring this project video
Buy electronic components and tools: https://www.utsource.net
So now that we have the 3D printed frame in our hands we can put everything together and see how it looks. I made a short video reviewing the CAD process from last time as well as showing the general assembly process and finally some footage of the final sign lit up. Not a bad outcome for around only $10 in parts and a few hours of work.
Here are some glamour shots I took of the sign in action as well. If you guys have any suggestions for future signs or methods I should try comment below.
- It is colorful with nice vibrant primary colors
- There are already commercially available neon lights which I could borrow the design from (and not have to come up with it myself)
- Finally, it is just a plain cool logo
After a quick google search I found a nice image of the original neon sign which I saved and imported into inkscape for editing.In inkscape I used the trace bitmap command under path to generate the light path using brightness to filter the image to that shown on the right above. Then I drew red dots for where holes would need to be on the frame for the EL wire to poke through and blue dots for support locations to bend the wire around. Finally I made sure the dimensions of the design were scaled to the desired final size I wanted the sign to be. With this done I saved the file as a dxf to allow it to be imported into solidworks.
In solidworks, with the dxf imported as a series of dots (image above) I set it as a construction sketch (yellow inner lines) and began drawing offset lines around the desired shape to form the footprint of the frame (blue lines). I connected all these lines to make a shape with holes where there would be no EL wire to save filament and shorten printing time. From this base shape I extruded upwards to form the 3D shape.
