• Motorised Program Counter
    Eric Hertz07/16/2024 at 02:07 1 comment
    Leaving this here mostly for myself...
    (Whoops! writing this up, I realize I fell for the classic blunder! But I won't share that bit, here...)
    Instead, I'll just say that couldn't this circuit be tremendously smaller if they ran <&= or >&=  instead of <&>?
    (I mistakenly thought I could reduce that and he rest of my circuit to *only* use =... by assuming that 90% of the time != means >, but then how would I account for the 10% where != means <? Duh. Still, <,=,neither is still fewer gates than this, so I guess that's an improvement)
  • 20 YEARS
    Eric Hertz02/04/2023 at 13:04 0 comments
    I was one lucky bugger in my youth in that I had a buddy who worked at HP and brought me surplus gizmos [I thought] he acquired for dollars...
    As I recall, he brought me two flatbed plotters, two 8.5in floppy drives, an ISA HPIB card with full manual (and BASIC instructions!), and a whole slew more that I was not at all worthy of.
    I loved that plotter... watching two interlocked doughnuts form from seemingly-random trapezoids was mesmerizing. I've saved (and modified) and replotted that file countless times over the past 25+ years. From the much more studio-apartment-friendly HP7475A [paper-fed] plotter I eventually acquired, to the wall-hanging plotter made of legos, to the Silhouette vinyl-cutter I got from Goodwill, to #The Artist--Printze wherein I wrote code to treat an inkjet like a pen-plotter...
    But nothing beat those old flatbeds, which I STUPIDLY took apart.
    They were exceptionally fast, and precise. The mechanics, if I understand correctly, we now call "Core-XY" but were far superior to anything I've seen since. (I later figured it out, from memory, and managed to extend it to three dimensions with legos and pulleys... long before I'd ever heard the term Core-XY). I liked that mechanism so much, after I finally pieced-together in my mind how it worked literally two decades later, that I tried to design a "business card" plotter around it #2.5-3D thing...
    Somehow STUPIDLY I took both those flatbeds apart. STUPIDLY. And STUPIDLY only managed to keep a few random pieces...
    Including the stepper motors, which are amazingly strong and fast, as I recall, and the weird oil-filled dampeners which nearly look like nothing more than "spare no expense" "eye-candy" yet I remember how smooth those stepper motors were, and fast, and maybe somehow those seemingly physically-useless oil-filled flywheels on bearings actually made that possible.
    Anyhow... WAY side-tracked. Man I was STUPID back then. Just downright stupid.
    Watching it switch pens was beautiful in and of itself. Such precision and delicacy and yet such speed. What the HE** was I thinking when I scrapped them?!
    In addition to the bipolar [4-pin] steppers, I also somehow managed to keep a stepper driver-board...
    And when I was finally smart enough to understand what a bipolar stepper was, it occurred to me that.... waitaminit. How could 2 bipolar steppers be driven by only 8 power transistors?!
    An H-Bridge is 4 transistors... And you'd need two for two windings in each motor! That'd be 16 power transistors, not 8!
    I mean, it's not like I *really* sat and thought about it, but it's been percolating for probably 20 years, until just now.
    And now I feel a bit stupid, again. But not nearly as stupid as I feel thinking about younger-me scrapping those amazing machines.
    Anyhow, a big build-up for something probably obvious...
  • Early Li-Ion Protection Circuitry
    Eric Hertz09/30/2022 at 05:35 0 comments
    I'm trying to fix the battery pack for an old 486 laptop. If I understand correctly, this was the first on the market with Li-Ion (as well as TFT!).
    I replaced the original 18650's a couple years back, then let it sit for a year or so in storage... And sure-enough one of the two pairs of year-old cells was completely kaput.
    So this time I looked at the circuitry in the pack to see what could've happened... and... well, I think I have a vague-ish idea.
    It would seem this thing's protection circuitry is very limited compared to today's.
    An actual fuse takes care of over-current. But otherwise it seems all that circuitry does only two things: cut off discharging when one of the parallel-pairs in the series is too low, and cut off output when it's not in the laptop (don't want it shorting on a paperclip!).
    Unless I'm missing something *that's all* it does.
    No charge balancing, despite its having a wire on each cell-pack.
    No thermal cutoffs.
    In fact, nothing to prevent it from charging (since the cut-off MOSFETs have body-diodes).
    I dunno what all.
    Funny thing is, the connector has four pins. Only three are used.
    Basically the entirety of this circuitry could be in the laptop itself, excluding the paperclip-fire-preventing transistors. Their gate could be on one of those pins... along with another pin for measuring in the middle of the series.
    And then...
    Well... I think this would've prevented what I guess must've ruined one of the parallel-cell-pairs:
    The over discharge circuit is *always* powered. From the entire series.
    Meaning:
    A) I probably forgot to charge it before storing, so the cells were already low.
    So, after a year of the LM393 comparator sipping 0.4mA, the pack was just *empty*
    B) I used cells that were not brand new, nor had been used the same number or depth of cycles.
    So, as the series cells discharged, one pair reached zero before the other, then began charging backwards from the other.
    Which most cell chemistries do not like. Heh.
    But the reason this intrigues me is that allegedly Li-Ions are basically unchargeable if allowed to drop too low, something like 1V. Yet  I've been running experiments on many old packs and finding, repeatedly, that they definitely can be recharged even if they've been sitting for years and measure less than a diode-drop.
    So, it makes me wonder about the thought-process at the early-days of the Li-Ion...
    NiCd cells, for instance, are known to be fine even if stored with their terminals shorted for years. In fact, I've heard that if you're planning to store them, then that's the best way.
    I wonder if that's basically what the designers of my 486 laptop were thinking... (though why would they bother with a low-voltage cutoff circuit? maybe that's not what it is?)
    BUT that logic only works if they're Not In Series. Because, if you have one cell at 0.8V and another at 0.78, and put a resistor between to drain them, then eventually you'll have one cell at 0.01 and the other at -0.01... and that negative charge is what does a cell in. As I Understand.
    I dunno  this laptop is pretty decent quality, and wasn't cheap when it was new, so I can't quite picture they were cutting corners.
    Anyhow, again, I did manage to recover one of the pairs, even though it was at something like 0.15V. The other, though... Nothing doing. For a moment I got it up to 0.8V, but then despite pumping current in its voltage began to drop.
    I'm no expert, so I figure that's time to call it.
    whoa, if I'm reading my notes right, the surviving cells are holding nearly the same charge as a regular pack of the same make of cells with its "proper" protection circuitry that never goes lower than 2V. (?!)
    In other packs...
    Well... I've looked at one from an iBook G3, and another from a pentium 150 (I think)... both had been sitting for years and definitely way below 1V per cell.
    MOST of the cells definitely have useable capacity left in them... Though, definitely diminished from their "new" capacity.
    Also a tremendously larger...
  • Homebrew Computers & Transistors, and surely more...
    Eric Hertz04/16/2022 at 08:05 6 comments
    Mid-May, just came across this draft from about a month ago... Still pondering the idea off-n-on.
    I'm almost certainly in no position to be, right now, but the past two months have finally calmed a bit, and I desperately need to feel like I'm accomplishing something, which I don't get outside my realm... which basically includes everything I probably should be, or have been forced to be, doing.
    So, I've been revisiting old ideas, one of which is that of building *something* from old CPUs I have laying around, but haven't the experience with to just throw into a project.
    Before the crazy-shizzle started (crazier than normal, which has been crazy itself)  I'd spent months (more?) on my TI-86, learning about z80s and more... #Vintage Z80 palmtop compy hackery (TI-86) . (Really, I'd probably kill two birds with one stone if I'd just pick up where I left off on that... but my brain doesn't switch tasks like these easily, there's a huge process involved, this is probably that process). Anyhow, one of the results of that project thus far is a renewed interest and much better understanding in the make-use-of-processors realm.
    So, now, I have a pretty well-mulled-over idea of a sort of "homebrew computer" build-process that builds it in pieces, each step along the way doing /something/ blinky and interactive. And a sort-of general-path that should work with a wide variety of CPUs I've stumbled on in my collection; z80, 6800, 6502(?), 8088... even up to the 486.
    E.G. The first step is an easily hand-wired board that merely shows LEDs for the address bus (maybe just 8 bits), and simply wiring the data-bus to NOP (jumper-disableable)... Oh, AND the circuitry necessary for single-stepping. This board will have a header for an IDC-Connector-cable (E.G. an old IDE cable?) connecting the necessary pins for 16bit addressing and 8 bits of data. Though, I'm half-tempted to make it even simpler by just using a chip-clip to breakout to the next boards.
    The second board will connect there, and add switches (and LEDs) for the data bus. Unlike other switch-driven systems like the Altair, this won't (alone/initially) be used to enter a program /into memory/ to be run later. Instead the idea is to have a small program which will be entered in "realtime." The processor requests an address, the user toggles the switches for the opcode, then hits "Step," repeat.
    Now, with two tiny boards we have 8 bits of the address bus visible on LEDs, 8 bits for data on switches and LEDs, and a step button.
    From there, I think the next board will contain a jumper-enableable diode-ROM (and couple/few-bit address demultiplexer) for a program maybe as simple as "jmp address 0". If I get this right, the Diode-ROM containing these instructions (this instruction?) could be mapped in various locations in the address-space via jumpers, and the default NOP from the previous board would be accessed otherwise. Now we have a binary counter (the program-counter) visible on LEDs and resetting at, say, a  selectable count of 4+3=7, 8+3=11, 16+3=19...128+3=131. Basically +3 because all the CPUs I've encountered so far have a 1-byte NOP and a 3-byte absolute-jump. And then, powers-of-two since its easiest to decode with one jumper.
    Anyhow, the idea is... I don't want to throw these efforts away, and they're too big to hang on the fridge... So, if Imma build a homebrew computer, maybe I can make each "step" along the way /useful/ even in the "end-product". Each step will introduce more features... When RAM's added, the switches/LEDs on the data bus from the second board will be used to load the memory. The RAM board then will probably add switches and 8 more LEDs for the address bus...
    One board early-on may add line-drivers/buffers, then break out to a new header with the same pinout...
    Another board down the line might add memory-mapping for more than 64k, So, those same boards from before could be moved /after/ this addition... same pinout....
  • Elderly batteries, Lappies, and other devices
    Eric Hertz07/31/2020 at 22:31 16 comments
    I've two old laptops I've been trying to use with some old software necessarily connecting to old hardware via old ports... thus we're talking a 486 and a p150.
    The 486 is actually a great machine; quality. I used it last year for #OMNI 4 - a Kaypro 2x Logic Analyzer
    BUT, after a year in storage, even though it worked great after the twenty years in storage prior, it started acting *really* weird; claiming it was running off the battery, though it was reporting 0% charged, and though it was plugged-in to AC... and not even attempting to charge the battery... and, if I recall [it's been *many* days fiddling with it, since], after just a few minutes' use, would briefly warn about a low battery and planning to drop into standby, but would actually shut off completely.
    The p150, as I recall, was doing similar, which is why I reverted to the 486... since I'd used it more recently.
    Long story short: It appears that:
    * upon losing BIOS-settings due to a dead [actually, removed, so-as to avoid leakage] CMOS battery, the default option for the power-button is standby, rather'n power-off. Thus, apparently the machine patiently waited to be awoken, for a year, sitting at the "now safe to shut off" screen, until sipping both the main battery and the standby battery dry...
    * the system apparently does not recognize that the main battery is connected if it detects 0.14V where /at worst/ the 7.2V battery shouldn't go below something like 6V... maybe it can't even measure that low... [interesting; two diode-drops?] Thus, won't even attempt to charge a battery it doesn't think is there.
    * I still can't explain the "Power source: battery" when plugged into AC; but
    * I *think* the reason it'd run for only a few minutes at a time is due to the *standby* battery; which is three NiCd[?] heatshrunk coin-cells, deeply hidden inside. AC would charge them while the unit was powered-off, then the machine would run off three friggin' coin-cells for a few minutes before they ran too low.
    THUS.
    It's not that I /need/ the thing to run off the battery, but that it's near /useless/ if it can only run a few minutes at a time... and...
    In many cases such an issue might wind-up an otherwise fully-functional machine in eWaste, presuming something internal like a faulty charging circuit...
    Well, I looked-er-over inside and out [which was not easy, mind you!], and besides a long-broken screen hinge and a couple stupid plastic tabs I broke off trying to open it, etc. this thing is near-pristine inside, going-on 25years old!
    So, then, I broke apart the battery pack and found 6 18650 li-ion cells [li-ion existed 25 years ago?!]... three parallelled, in series with another three parallelled. And, each parallel-combination measuring 0.07V. Yikes.
    Now, if you believe the hype... a li-ion lower than something like 2V is "useless" and unusable, some even say "dangerous," and must be immediately disposed and replaced... Something about dendrites shorting plates, thus never being able hold a charge. Something else about big-enough dendrite-shorts causing huge currents and flames?
    While those theories may have merit in some extreme cases, I'm sure there are varying-degrees of "dangerous" and "useless." And I beg to differ, regarding their uselessness; I think the scenario I've described above is a *perfect* use-case.
    [Similarly applicable, I imagine, and have unwittingly encountered, with many cell-phones, tablets, netbooks, etc.--portable devices of all sorts!--which literally won't turn on without a battery, regardless of a decent charger/power-supply]
    The question then becomes, how to get my laptop [or other device] running... and /now/?
    After a bit of digging, I found that there are many rebels and dare-devils out there [thank goodness] who've had and reported various successes [and failures] trying various methods to revive Li-ions which've been depleted *far* below 2V, some...
  • Starter battery, wee!
    Eric Hertz07/14/2020 at 00:36 0 comments
    forgot to turn off my headlights, and listening to the radio... guess what happened.
    So, I figured it was time to run an experiment brewing in the ol' noggin' since I saw here of someone charging their car starter battery from an 18V cordless drill battery, and not long after seeing that, @Ted Yapo tried [nearly successfully] to get enough charge outta a coin-cell...
    Well, I've got a *bunch* of USB power-packs... three in series gives 15V.
    Nice thing about these over, say, a regular ol' battery [even a cordless drill battery] is they have boost-converters built-in... so as they discharge, they still put out 5V. It's a bit like a built-in joule-thief. Also, built-in current-limiting, which could be a mixed blessing depending on how it's implemented... oh yeah, and thermal-protection!
    So here's a weird culmination of coincidences:
    the way I wired 'em up was via bulky usb power cables I built a while-back... their housing hot-glued to the connector.
    Then I inserted my ammeter between it and the cigarette lighter outlet...
    2.4A --Perfect.
    The batts are rated for 2.1, but I looked up the chips once, and they're set to 3A.
    I thought maybe it was actually limiting, 'cause 15V -> 12 would mean for a lotta wire resistance to only be 2.5A...
    So I figured the limiters doing their job and plugged it in straight. Nope. One of the batts quit outputting. Grabbed another, tried again with the meter, 2.4A... again trying direct, again kaput batt.
    OK, so, apparently, again in the last few completely unrelated projects, my ammeter's resistance had a big effect; this time quite handy.
    I estimated ~1ohm between the car batt and my usb batts, to give that 2.4A... so, yahknow, whatever tiny resistance is in my meter was *just* right.
    There's a coinkidink!
    These things got *hot*... enough to melt the glue, still, not so hot as to shut down... though i watched pretty closely.
    I estimate about 8W lost in the hookup, and 24W, then, into the car batt... 24Wh, actually; it happened to take almost exactly an hour to drain the batts 'till one went kaput.
    Weird thing, someone walked-up needing a jump of his own... and just when my charging completed he got his started. I tried mine, and... yeah! I guess it worked! Nice to've had the backup of his services-offered, anyhow.
    Other interesting observations: the one holding the least charge [as indicated by its bargraph] seemed to drain fastest [makes some sense, lower voltage, higher amperage to boost]. Though, oddly, the one with the most charge, seemingly draining the slowest, [and, oddly, with the most airflow for cooling] went kaput a couple times. Can't quite wrap my head around it, but I guess it was prb for the better, as I bet the others probably didn't mind a break. ...and let that glue cool/harden.
    Interesting metaphors of man-hours, differing-abilities [and stubbornness], John Henry, and managers insisting on coffee-breaks...
    Random-ish thought also revealing the coinkidinkness of it all... that if I'd tried four batteries at 20V? Well, if my setup was otherwise unchanged, we'da been at ~7A... and... it just wouldn'ta worked. So, I guess some amount of luck or coincidence or something that put pretty much all those variables pretty much randomly thrown together not only at a functional point, but also near-maximal.
  • DC grounding, real-world measurements
    Eric Hertz07/04/2020 at 03:02 0 comments
    Scenario:
    12VDC [car battery]
    a computer [Raspberry Pi Zero, + LCD + hub/keyboard, etc.] with internal DC-converters... ~1A, 12V
    a USB-attached external hard drive, ~1A, 12V
    each with identical five foot heavy-gauge power cables powered from the same point.
    devices not yet connected via USB
    Measurements:
    ~20-30mV difference at negative input to computer vs. negative input to powered-off drive [at the devices]
    Thus ~20m ohm [0.02 ohms] on the negative power wires...
    Both devices powered, the mV difference between their negative inputs varies between ~+15mV and -30mV depending on what each device is doing.
    No biggy, right?
    Connect them via USB!
    NO.
    Here's a resettable fuse on the drive's negative input:
    <todo, grab picture from old phone with good macro mode>
    Description: got so hot it looks nothing like a fuse anymore, more like a piece of burnt charcoal, complete with burn marks all around on PCB.
    Now, I'm not certain that came from this setup, or the fact that my stupid DC Barrel Jack on compy was all-round metal, allowing one to touch tip-to-shell on insertion.
    BUT: continue with me regarding the previously-described setup/measurements.
    ~20mV difference at negative terminals
    ~0.02ohms on power cables' negative wire
    ~1A, 12V to each device
    Devices NOT connected to each other via USB cable [yet]
    Connect ammeter between USB-A port's shell at compy, and USB-B port's shell at drive.
    ~70mA.
    "OK, so a couple LEDs, big deal! USB ports handle 500mA!"
    How does Ammeter measure current?
    Puts a small resistor in series with probes and measures voltage across the resistor.
    [a resistor whose value has to be greater than probes, which are roughly the same gauge, and together about the same length as the power cords... so they're prb ~0.02ohms, then per 10-to-1 rule-of-thumb series resistor is probably ~0.2 ohms, which would make sense being that the minimum voltage-setting is 200mV and the amp-setting is 10A "max" but displays 15A if pushed to do-so]
    So, it's not measuring the current that would go through the shield/VBus-, but some *fraction* of it... plausibly 1/10th!
    700mA might surge through that when the drive starts writing/seeking!
    AND: that may go *either* way, the port may handle 700mA, but what about -700mA?
    That's just the tip of the iceburg.
    But, continuing that experiment, imagine the shield braid is roughly the same gauge as the power cords [when not wrapped around the USB signals] and the cable about 5ft... ~0.02ohms, just like the power cords' negative wire... so, now, if drive is idle/off and compy's running full-tilt at 1.5A, 1A will go through compy's power-cord's negative [0.02ohms], and 0.5A will go through the usb shield into the drive, and out its' power cord... [0.04ohms]. not so great. And, anyhow, 1/3rd of compy's current won't return down compy's power cord, when the drive is off/idle! And vice-versa!
    Think that's not a problem? Still OK with a self-powered USB device sinking and sourcing 500mA whenever?
    OK, how 'bout this:
    Compy has a DC-DC converter which was designed with a far underrated input capacitor... [I figured this out later. Bear with me]...
    So, imagine a DC-DC buck converter...
    How does it work?
    it has an SPDT switch and an inductor.
    In one position the inductor current "charges" from the input-voltage [12V], and flows into your device/load.
    In the other position the inductor current "discharges" into the load.
    It switches *really fast* so that inductor barely has a chance to "discharge" before getting "recharged."
    Thus, in both switch positions the current through the inductor and into the device/load remains roughly constant, and so then does the voltage.
    "OK, what's the problem?"
    When the inductor is charging, the full device current [say 1A] flows from the source and back to it. So, half the time the battery supplies 1A at 12V [for...
  • Data, still, and DC grounding
    Eric Hertz06/29/2020 at 06:13 0 comments
    Another setback, rather major, being the connecting of the external drive... eventually not only completely blew out a USB port, but damaged the entire hub it was connected to wnough to cause frequent I/O errors.
    It would seem there's quite a bit to be considered in DC power distribution.
    Imagine a 5 foot long power cable to the computer and another to the external hard drives, both connected to my 12V car battery... say that's 1A@12V for a lowly PiZero+display and 3A@12V for two hard drives... say there's one ohm in those cables... now "ground" at the computer is 1V above battery-ground, and "ground" at the drives is at 3V!
    Now, imagine what happens when that USB cable is connected!
    ... worse, still, I did some falstad circuit simulations today to see about the best place to put a ground when using buck converters... and I was reminded of another factor I hadn't been considering; powering up a buck converter causes a huge power surge.
    So, Usb drive has a power switch, let's ground 'em through the USB cable *before* powering up.... compy-on, no biggy... maybe draws a little current through the usb shield/gnd wires, but certainly most through its power cable... now, switch on the 3A drive... heh. Huge surge spinning up, of course, but also huge surge charging the buck converter's input capacitor, huge surge charging up the inductor, huge surge charging up the output capacitor, and the motors aren't even spinning yet!
    So... I replaced the hub, and *thankfully* that seems to have been the only damage.
    But, I need to do some serious grounding thoughts before continuing.
    Stupidly, I had forseen some of this; I was building a power-bank last year[?] which has numerous floating-output DC converters for pretty much *exactly* the purpose of preventing such things... but, ultimately, it was such a hassle, and I guess I *really* needed to get some actual compy-time in... feel like I was actually progressing toward my original goals... and, well, I think I was more cautious about it in the beginning, then kinda forgot about it... and I guess it finally came 'round to bite me in the ass.
    Thankfully, again, I think the only damage was to the hub. Although, I ran some extensive tests [copying a large file 100 times] and found that, in fact, *somehow*, despite *numerous* checksums and retry-mechanisms all along the process [sending the command over USB to read the sector, reading the sector, transferring it over USB, transferring it *back* over usb, writing the sector, nevermind the process reading it back for comparison], somehow it did the job once or twice *without* 'cp' complaining, and *with* erroneous data! I don't understand how that's possible! There should've been a checksum failure somewhere, wherever that was it should've automatically reattempted until there wasn't, or /errored/... but no error, and still bad data. HUH.
    So, now, no idea whether all those millions of files transferred to my backup drive, and from there to my main drive, are accurate... am I really going to 'diff' them all? Especially after the reorganizing? UGH. I was *SO* ready to wipe those original drives so I could finally put this *years*-long process behind me.
    And I still haven't figured out what to do about grounding, short of dangling a wire off each component and installing a bunch of friggin' banana-jacks in the van's wall.
    And, I'd much rather be working on #The Artist--Printze, [surprised I didn't have grounding issues with that!] or finally getting to #Floppy-bird, or several others... but... not without a compy... a /properly-grounded/ compy...
  • Data
    Eric Hertz06/14/2020 at 06:26 0 comments
    There've been *big projects* that maybe deserve their own page... but tonight I'mma rant about a "little" [160 friggin' Gigabytes little] discovery...
    I'd fought for literally *months* to first consolidate all my old machines' data onto one drive, then slowly organize it better... this was a big process, requiring going through each drive in reverse-order [newest to oldest], making sure they were organized similarly for comparison/merging/deleting duplicates/keeping the oldest dated duplicate and so-forth via home-brew script, yet retaining the original directory structures /as well/ should I ever have one of those "I remember where it /was/, now where did I put that?" moments... so, now two copies of everything [well, hardlinked] from three different machines, then a copy of the newest machine... then merging/comparison, etc. Then *finally* [literally months later], when that was finished, I could move all that stuff from that latest machine's directory-structure to one that makes more sense now. Doing all this with hardlinks is key, as it means each machine only occupies a little more space than original, despite there being two+ copies on the new machine [and far more on the backup drive] for some time.
    Anyhow... I *finally* finished all that merging after months, then finally got rid of those old dir-structures... and finally started on, and got a ways in, reorganizing how I'd rather it be organized... despite the nagging feeling something was missing... just couldn't place my finger on what. And, surely that *couldn't* be the case, because I was *very* methodical and meticulous in my process, been literally working-out how I was going to go about it *for years*. I backed-up each machine's *actual* drive to my backup drive before starting. So nothing could be missing... right?
    Well, shit... some brat reminded me of an old project I kinda intentionally forgot... [as best I could, anyhow, being that it affects me still, every day]... which, I guess, is to say it's getting near the time the trauma's worn off enough that I might take a look at what happened...
    and...
    It's GONE.
    Nowhere to be found... like, except for my HaD.io project-page for it, and a way-outdated github upload, like it never friggin' existed.
    Which, frankly, I was /kinda/ OK with, not wanting to revisit the trauma... but if *that* was missing, what else might be...? And so I went looking, and sure enough my favorite project of all-time was missing, as well. So then I was panicked... and *thankfully* eventually found that somehow I just forgot to update its version number, so it was stored in a previous project's folder...
    Whew.
    but... still that nagging feeling... so tonight I got out an old backup drive... and... Yeah.
    Somehow, I can't even begin to recall, the drive from my newest machine, prior to my current one, is *very* *very* different than the last backup made of that machine. I mean *very*.
    And... the last backup...?
    Well, it looks like about 160GB of sorting, merging, looking for duplicates, etc. again... only this time I've got two *very* different directory-structures to deal with. WEE!
    But, yeah, there's a *lot* of stuff in there to confirm that "something's missing" feeling I had.
    Lessee... I think I topped-out at 10MB/s between drives before... so... 16,000sec... about 4-5 hours? to transfer to the new backup drive...
    The backup drive and computer drain the car battery in about that, but here with two drives... Can't start the engine to recharge midway; the starter drops the batt voltage too low to keep the inverter running = unhappy drives... so, I've gotta do this in steps. I *think* rsync, as setup in my backup script, can resume where it left-off. Though I had a problem with CTRL-Cing /something/ like this, then resuming... I think that was 'cp', which left a half-written file whose date was newer than the original, so didn't "update" it when I tried again... yeah, I think my rsync...
  • Your goop ruined my vias!
    Eric Hertz05/21/2020 at 08:00 3 comments
    This was sitting as a draft, a bit outdated; the printer now works [except for a few dead nozzles], but I'll write about that adventure later....
    been trying to get an old printer running... it's a portable doodad which probably cost some executive a small fortune back in '91. But it's got a sticker on it for $3.50, I'm guessing an old buddy grabbed it from a thriftstore back before he decided guitars were better at picking up chicks than robots, and gave everything to me... I held onto the things that could plausibly one day be useful to <i>someone</i>.
    This printer I never planned to find a use for, and actually put almost immediately in a box marked "To Donate" [to a thriftstore]. I'd done quite a bit of research buying my desktop photo-quality printer, I'd planned to hold onto for decadeS, and invested nearly $300 to do-so. I didn't even have a drivers' license for another fifteen years after, so I really saw no need for a portable inkjet... Sufficed to say, this printer's been in *my* storage for nearing 20 years... but these days I actually have a use [if not a need] for a *portable* printer...
    so, cool-beans!
    This thing's actually EXTREMELY well-documented... right down to schematics *and* functional descriptions of the subcircuits. And the service manual's even kinda funny in some places. Its ink cartridges are well-documented, and even still available nearly 30 years later; which actually isn't a huge surprise, because at one time they actually made multiple printers, over several years, even from different brands, which used the same cartridges.
    [This thing shoots out droplets at <b>12 Meters Per Second!!!</b> I wonder how/if that could be used?]
    So... this thing might be a useful tool for some time, if not, frankly, a piece of test equipment which again might be useful for quite some time.
    Here're some thoughts, in the "hacker" realm... old printers like these were *designed* to be compatible with even older printers... plausibly all the way back to the days when one might literally log on to a system with only a keyboard and [dot-matrix? Teletype?] printer... no monitor!
    Simple commands can be used to print one line [maybe even one character?] at a time. E.G. in linux: 'echo "hello" > /dev/lp0' And maybe even one /character/ at a time E.G.2 'echo -n "a" >/dev/lp0'. Nevermind the fact they'll work with *countless* machines of the era, without special drivers!
    Now... imagine how friggin' useful such a thing could be in *this* era... e.g. attached to an arduino... true, it's a little more difficult than using printf [or cout?] statements, because it has a parallel, rather'n serial, interface. But only slightly. in fact, serial to parallel adapters existed for exactly that purpose, and even modifying printf to output parallel isn't particularly difficult. Oh, sure... debug-info may be best-suited to a console/terminal window, but having a physical printout of whatever you want at your fingertips?! How is it this ain't "a thing"?!
    I dunno what newer printers do, but older ones like this were actually capable of *both* "text-only" <i>and</i> graphics... and that was no small feat on their part. In fact, it was so difficult, printers of the time had processors *on par* with the computers' CPUs of the time, just to handle e.g. rendering inbuilt fonts... Similarly; modems, and even some [e.g. Commodore] floppy drives were full-on computers in themselves, again, on-par with the systems that used them... because those seemingly-simple tasks--many of which we've exiled to "obsolete," such as converting a single byte of ASCII input into Hundreds of pixels on a piece of paper--were once handled by the devices themselves, rather than by the computer. In a way, many older peripherals are *way* smarter than the newer, seemingly more sophisticated ones, which require the *computer* and drivers to do all the work. [See also "winmodems," wavetable MIDI, and "framebuffer console"]...
    So, yahknow......
