Changes to HTTPS Streams
11/26/2021 at 21:48 • 1 commentAwhile back, SomaFM changed how they handled HTTP/HTTPS when it comes to playlist files. Basically, if the player requests a PLS file using an HTTP link (I.E. http://api.somafm.com/christmas.pls), than the individual links within the file will be HTTP links, and vice versa.
This is a very logical change, but it actually broke my script depending on which OS/player you were using. Now that Remoticon is over and I've had some free time to get back to it, I've gone through and standardized everything to use HTTP other than the initial call for the channels.json. I know this seems counterproductive in 2021, but unfortunately, most of the command line players I'm using for the backend of this script don't support HTTPS streams.
So if you ran the script within the last couple of weeks and it just failed silently, give the latest version on GitHub a try and see if it fixes things.
Version 1.7 Released
12/10/2020 at 01:59 • 0 commentsNew version of the script is now available on GitHub and through PyPi. The big news for this version is preliminary support for running on Windows. Right now only MPlayer seems to work, but it's a start.
For those of us running Unix-like systems, the major change is the ability to specify the desired Chromecast target from the command line:
somafm -c HackCast -
Version 1.6 Released
05/17/2020 at 20:13 • 0 commentsAfter a few months of puttering around, I'm ready to call version 1.6 stable. I've also added the project to PyPi, so you should be able to install it with the command:
pip3 install somafmA lot of new things have been added in version 1.6, but the biggest one is probably support for other media players (mpg123/mpv) in addition to MPlayer. The script will still use MPlayer by default, but if it's not installed and one of the others is, there's now a fallback. There are some drawbacks though, as mpg123 doesn't support high-quality AAC streams and mpv is slow and overall a bit janky. But at least the option is there.
You can now turn off track sync when streaming to Chromecast devices, which is good if you want to play media "headless". Desktop notifications won't pop up for Station IDs (oh, and I fixed broken desktop notifications), and there's even some experimental support for custom notification commands which could potentially be used for things like showing track data on an external display (that's what I'm planning on, anyway).
Give it a shot and let me know what I broke.
Christmas is Saved
12/10/2019 at 18:09 • 0 commentsThe holidays are upon us, and that means even SomaFM has been playing the following songs pretty regularly (albeit in forms you probably haven't heard before):
Baby It's Cold Outside
Santa Claus Is Comin’ To Town
It's the Most Wonderful Time of the Year
It's Beginning to Look a Lot Like Christmas
Thanks to these holiday classics, I finally noticed a bug that's been there from the very beginning. I was using apostrophes as delimiters when parsing the stream info coming out of MPlayer, which obviously (in hindsight, anyway) means any song title with said punctuation was getting truncated.
I've changed how the MPlayer output is parsed which fixed the issue, and the new version is already up on GitHub. Just in time for any holiday parties you might have planned.
Station ID Highlighting
08/12/2019 at 19:35 • 0 commentsOne of the features I snuck in for v1.5 was the ability to highlight known station IDs, the little clips played to remind you what channel you're listening to. They are often used to add a little color to the listening experience by playing various messages or clips. For example when listening to DEF CON Radio, the songs are intermixed with short sound bites pulled from talks given at previous cons.
When looking back at an hour worth of streaming DEF CON Radio, the new highlighting feature makes this readily apparent:
Originally I had planned to simply omit these clips from the track listing, but I think highlighting them ends up being more useful. Or at least, interesting.
On a related note, not all the channels start their ID with "SomaFM", and I've only populated the list with the ones I've seen while listening. But it's easy to add new IDs to the list to check for, so perhaps that's something the community will eventually be able to assist with through pull requests.
Life after v1.5
08/10/2019 at 03:02 • 0 commentsI made the stable v1.5 release in honor of SomaFM's annual live stream at DEF CON, and I have to say, the program already has progressed a lot farther than I had initially intended. It started as a quick little script to keep me from having to use the web player, and now somehow it's evolved to the point I'm using it to play Groove Salad on my Chromecast.
Still, there are a couple things I'm thinking of adding:
- Logging track info to file
- "Headless" Chromecast mode, that starts Cast and then exits
- Recording streams (I've seen other players with this feature)
I initially wanted to support player backends other than mplayer, but honestly unless somebody requests it, I'm not sure there's much point.
Tom Nardi
