First truly functional version.
Laser cut from food-safe 3mm POM plastic, filler rod wrapped around the extensions for hinge and locks.
Feedback:
- It does work
- The 3mm x 3mm POM is definitely robust enough
- The hinge / lock system is not very good yet
- Squishes the teats, water doesn't get to wash between the holder and the teat
- It is a bit large
