1Attach Thermal Adhesive to Heat/Coldsink
2Attach Peltier to Heatsink via Thermal Adhesive
Remove the blue protective plastic from the thermal adhesive. Place the Peltier module on the thermal tape numbers down
3Attach Thermal Adhesive to Peltier and Attach Cup Holder
Apply 2 pieces of adhesive tape to the Peltier heater/cooler, remove the blue plastic from the adhesive and attach the cup holder. Make sure you get it centered the first time as the adhesive is very strong and the Peltier units are fairly fragile!
4Solder 2 Wires on Both Red and Black Wires of Peltier
Split the red and black wires into 2. Don't forget the shrink wrap
5Attach Peltier Wires to H-Bridge
Attach both black and both red wires to the H-Bridge as shown. The reason for splitting the wires is to take advantage of both sides of the dual H-Bridge for maximum current. The Peltier can pull ~4A at its peak.
6Connect the +12V Supply Power and Ground Wires to The H-Bridge
See the Orange and Black Wires in blue terminal block in the photo above and Schematic
7Create 3 Single Male to Dual Female
Cut solder and shrink wrap 3x Single Male to Dual Female jumper wires like shown in picture
8Connect the Wires Created in Previous Step to the H-Bridge and Arduino
Arduino UNO H-Bridge Pin 9 ENA, ENB Pin 10 IN2, IN3 PIN 11 IN1, IN4 -
9Place the MLX90614 into 3D Printed Enclosure and Attach Wires to Sensor and Arduino
Arduino Uno MLX90614 SCL SCL SDA SDA GND GND 5V VCC -
10Connect the Arduino to the Computer via USB
Use the USB A to B cable to connect the Arduino to a host PC running the Arduino IDE (Version 1.8.9 recommended )
