Hackaday.io Hackaday.io
Sign up Log in
YG-Scanner:198USD 3D Scanner &Holographic Creater
As Anaglyph/VR/Holographic video creater, point cloud file (<0.2mm) could be also gotten by YScanner (199USD)
yuanganYuanGan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
  • Hackaday Prize 2019
View Gallery
860
2
10
11
Team (3)
  • yuanganYuanGan
  • makerfabsMakerfabs
  • alexpanaleXPan
Join this project's team
hardware
completed project
3d scanning VR 2019hackadayprize holographic anaglyph 3D
This project is submitted for
  • Connected World Contest
  • Beautiful Hardware
This project was created on 08/12/2019 and last updated 6 years ago.
Description
1. Affordable: Acrylic glass is chosen for the device as it cut the cost dramatically(DIY suit 199USD,Assembled 268USD).You will find it here: https://www.makerfabs.com/index.php?route=product/product&product_id=6162. Anaglyph/VR/Holographic videos could be achieved from object.3. User-Friendly:NO professional background needed4. it will calibrate itself without calibration board.The resolution could reach to 0.2mm.5. Only one USB cable is using for the power supply and the data transfer.6. It supports Plug & play. 7 You can DIY your own 3D Scanner &Holographic 3D CreaterWe have a facebook group for you: welcome to join us: https://www.facebook.com/groups/2228103634146968/?ref=group_header<
Details
Log In/Sign up to comment
Sign up with Github
OR
Nicolas Rollin wrote 07/14/2020 at 19:23 • point
Where is the source code ? What kind of camera, can it fit on an arduino ???
or is it only a commercial scanner
YuanGan wrote 08/12/2019 at 13:39 • point
any comment is welcome if you are interested in this area.
The 2016 Hackaday Prize
The World's First Open Source Tongue Computer Interface. Empowerment for the Mobility Impaired. Telekinesis with Your Tongue.
Project Owner Contributor
Pallette
dan-levineDan Levine
Sarah P.C. Is a new kind of PCs in the old thinking of using a computer .
Sarah Programmers Computer v1.0
ebram-dawoodEbram Dawood
I've always been a fan of Stephen Hawking's signature speech synthesizer, so I made a publicly available version of it!
80speak - Online DECTalk Speech Synthesis
lixie-labsLixie Labs
Aquadcopter can make a 3D &2D map with dimensions
Besocopter
mahmoudbasyony1mahmoudbasyony1
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "YG-Scanner:198USD 3D Scanner &Holographic Creater", please tell us the reason.
Send message
Remove Member
