1. Affordable: Acrylic glass is chosen for the device as it cut the cost dramatically(DIY suit 199USD,Assembled 268USD).You will find it here: https://www.makerfabs.com/index.php?route=product/product&product_id=6162. Anaglyph/VR/Holographic videos could be achieved from object.3. User-Friendly:NO professional background needed4. it will calibrate itself without calibration board.The resolution could reach to 0.2mm.5. Only one USB cable is using for the power supply and the data transfer.6. It supports Plug & play. 7 You can DIY your own 3D Scanner &Holographic 3D CreaterWe have a facebook group for you: welcome to join us: https://www.facebook.com/groups/2228103634146968/?ref=group_header<
Where is the source code ? What kind of camera, can it fit on an arduino ???
or is it only a commercial scanner
