This is our main part of our system. which is responsible of removing 99.99% of viruses, bacteria and parasites. Where the water passes from 3 phases in the filter are membrane filter, iodine crystals and charcoal filter respectively.
This is our first step of LifeUnit how the system works. First water passes through a water filter which is made of advance hollowfiber technology. With the help of DC sucking pump in presence of lithium ion battery. In a final result you got a clean fresh water. Removal of 99.99% viruses and bacteria.
In this step we will first fix the battery in hosing. Next we will have to check the all electronic components. Insuring all components are working well like charge port, and pump is work
Now need to fix the dc pump in it hosing. In below picture we can see how we have fixed the dc pump. After this we need to connect the PCB circuit board with dc pump with soldering. In this step we need to make right connections means +ive with +ive and --ive with --ive side of pump motor and circuit board with soldering. Otherwise dc pump will work in revers mode.
Electrical components are the heart of our LifeUnit . They are responsible to give it to life as a suction system. We are using 1200 mah lithium ion battery cell 18650 which is very well known in building lithium ion battery. Second we are using a suction pump and last one is the brain of our electronic system circuit. which is responsible to charge the battery also operating the suction pump.
