Prototype #3 (2019):
Prototype #2 (2018):
Some overview slides: https://docs.google.com/presentation/d/1vobfSEhb0oGUbzrP773AvgAFrEsGztFD6GFTlhZPUSs/edit?usp=sharing
See more details here: https://jgeating.wordpress.com/portfolio/swerve-robot/
Prototype 1: 3 omniwheels with 80mm ginormous [oversized] brushless motors. The wheels were ripped to shreds, and lack of traction control made this very hard to get highly dynamic motions. Was controllable, but nowhere near as agile as a human.
Prototype 2: 3 wheel swerve drive - Supervised a senior design team to make this one. Same 80mm motors as previous build with 63mm steering motors at a ~4:1 ratio. Friction limited, and iterated on the wheels 3 times before settling on Colson wheels. Still developing, but it was overengineered, super heavy, and unwieldy. Used sliprings with motors mounted directly to the steerable body.
Prototype 3: four wheel swerve drive - Again, supervised a senior design team to make this one. skateboard hub wheels for the four drive wheels. Focused on making as low profile as possible. Total robot height was ~5in. Used custom sliprings to transmit power and signal to the hub motors.
VESC motor controllers used for all three prototypes. CAN bus controlled from an Arduino Due.
Always interested in collaborating and getting feedback, so hit me up if you're interested. I live in the Boston, MA, USA area.
9/8/2019 update - metal build of prototype 3 underway:
NEBRA Labs
Russell Cameron
David
Charles Galambos
Start curating your IP on this - Kiva Robotics (that run Amazon's warehouses) and others would love to get off the X-Y grid that their current designs require.
