Input with tactile Push button.
08/26/2019 at 23:46 • 0 commentsToday i decided to use tactile push button to get binary input unlike the arduino code i had to do math. Encountered my third AVR i/o avr register PINx.
//This Code is a simple i/o using tactile switch button and a LED. #define F_CPU 16000000L #include <avr/io.h> #include <util/delay.h> int main(){ DDRB = 0x01;//Setting PB0 as output PORTB = 0x02;//Activating internal pullups of PB1 while(1){ if(!(PINB & 0x02)){ PORTB |= 0x01;//Bitmask operation } else{ PORTB &= 0xFE;//Bitmask operation } } }
RGBlinking with Arduino.
08/26/2019 at 02:37 • 0 commentsToday i wrote a simple blink code, with a little twist. It loops through all 3 colours of an RGB LED and then becomes White.
