Hackaday.io Hackaday.io
Sign up Log in
ps-01
Software synthesizer running on Particle Xenon
wojtek-siudzinskiWojtek Siudzinski
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
455
0
2
4
Team (1)
  • wojtek-siudzinskiWojtek Siudzinski
Join this project's team
  • Project's repository
  • YouTube playlist
  • Soundcloud playlist
hardware
ongoing project
Particle firmware xenon Trellis synthesizer MUSIC I2S
This project was created on 08/30/2019 and last updated 6 years ago.
Description
Inspired by Pocket Operators from Teenage Engineering and still being in love with MOS6581, I decided to build a similar device on my own.
Components
  • 1 × Particle Xenon
  • 1 × Adafruit Trellis
  • 1 × Adafruit I2S Stereo Decoder - UDA1334A
  • 1 × USB Host Breakout - MAX3421 Electronic Components / Misc. Electronic Components
  • 1 × 320x240 TFT LCD - ILI9341
View all 7 components
Project Logs
Collapse
  • React/Flux like pattern for the UI
    Wojtek Siudzinski • 11/29/2019 at 18:04 • 0 comments
    A bit different update than the other ones as it's mostly focused on the software part of the synthesizer.
    I had a problem that boiled down to figuring out a straightforward (and fast) way to reconcile many inputs/outputs.
    I ended up using a pattern similar to React/Flux:
    You can read more about this pattern on my blog.
  • Updated UI for the new screen
    Wojtek Siudzinski • 10/13/2019 at 13:20 • 0 comments
    More information in the UI documentation
  • Replacing Trellis LEDs
    Wojtek Siudzinski • 08/30/2019 at 21:45 • 0 comments
    Replacing the LEDs in Trellis keyboard and some look into the actual hardware prototype.
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ps-01", please tell us the reason.
Send message
Remove Member
