React/Flux like pattern for the UI
11/29/2019 at 18:04 • 0 commentsA bit different update than the other ones as it's mostly focused on the software part of the synthesizer.
I had a problem that boiled down to figuring out a straightforward (and fast) way to reconcile many inputs/outputs.
I ended up using a pattern similar to React/Flux:
You can read more about this pattern on my blog.
Updated UI for the new screen
10/13/2019 at 13:20 • 0 commentsMore information in the UI documentation
Replacing Trellis LEDs
08/30/2019 at 21:45 • 0 commentsReplacing the LEDs in Trellis keyboard and some look into the actual hardware prototype.
