Software synthesizer running on Particle Xenon
View all 7 components
A bit different update than the other ones as it's mostly focused on the software part of the synthesizer.
I had a problem that boiled down to figuring out a straightforward (and fast) way to reconcile many inputs/outputs.
I ended up using a pattern similar to React/Flux:
You can read more about this pattern on my blog.
More information in the UI documentation
Replacing the LEDs in Trellis keyboard and some look into the actual hardware prototype.
View all 3 project logs
Carson Herrington
brtnst
AndrewMcDan
Inventive Robin
Yes, delete it Cancel
You are about to report the project "ps-01", please tell us the reason.
