System Implementation Details
The system is built around an ESP32 microcontroller acting as the main controller and protocol bridge.
Modbus RTU Interface
- Modbus RTU communication is implemented via RS‑485, using transceivers such as MAX485, SP485, or SN65HVD1781
- Supports Modbus RTU master read/write operations
- Fully compatible with PLCs and industrial Modbus devices used in real‑world applications
Network Connectivity
- Wi‑Fi: used for cloud communication and remote monitoring
- Ethernet: implemented via LAN8720A PHY, providing reliable wired connectivity for industrial environments
- All collected Modbus data is transmitted using the MQTT protocol
Data can be monitored through:
- Smartphone applications
- PC / laptop tools (including custom C#‑based applications)
Software Platform
- Firmware developed using the Arduino IDE
- Modular structure allowing easy expansion and customization
- Proven stable in continuous operation with PLCs in deployed applications
Thermal Management
When operating, the board temperature typically reaches 45–55°C, which is acceptable for the selected components. To ensure thermal stability, the board is equipped with:
- A 5V cooling fan
- Heat sink activated when the temperature rises
Power and Electrical Characteristics
- Input voltage: 7–40 V (AC or DC)
- Power consumption: < 2 W
- Over‑current protection: 100 mA fuse
- Over‑voltage protection: TVS diode (6.8 V)
Modbus RTU Specifications
- RS‑485 baud rates: 1200, 2400, 4800, 9600, … up to 115200 bps, and up to 512000 bps
- Maximum number of slaves: up to 32 devices on a single bus
Ethernet (LAN8720A) Specifications
- Bandwidth: 10 / 100 Mbps
- Operating temperature: –40°C to +85°C
- Ethernet isolation: HanRun HR911105A transformer
Open Hardware & Availability
- Altium schematic files and sample source code (Modbus RTU read/write, Wi‑Fi/Ethernet communication, MQTT data transmission) are available and can be shared with interested developers.
- PCB layout (Altium) files can be provided upon a small donation (e.g. “a cup of coffee” support).
- Demo boards are available and ready to ship upon request.
Contact & Demo
- Contact: thanhnamlt5@gmail.com
- Demo video (working with MFM383A parameter selection): 👉 https://www.facebook.com/kuem0912/posts/707666223039027
namnam
gojimmypi
mihai.cuciuc
STEMinds
hi dear, can you contact me grigth123@gmail.com
