Release Notes (2019.10.16)
10/16/2019 at 08:55 • 0 commentsVersion 0.1.11 Update
Stabilized the process about resource download.
Release Notes (2019.10.10)
10/14/2019 at 02:33 • 0 commentsOctober 10, 2019 (v0.1.10)
Released:
- Fixed the bug that skiiiD was not working right after auto-update.
October 07, 2019 (v0.1.9)
Released:
- Added the Neopixel module's library for Maker Faire Seoul 2019.
- Improved the UX about auto-complete.
September 25, 2019 (v0.1.8)
Released:
- Supported the multi-language for library's tooltip(English, Korean).
- Added the sub function that display parameters to auto-complete.
Release Notes
09/03/2019 at 08:34 • 0 commentsAugust 30, 2019 (v0.1.7)
Released:
- Supported the new board(Arduino Nano).
August 22, 2019 (v0.1.6)
Released:
- Modified the process of pin recommendation and setting.
August 05, 2019 (v0.1.5)
Released:
- Supported the mac version.
- Modified the process for serial port.
- Moved the cursor into loop function when new project.
- Added the board change function.
June 05, 2019 (v0.1.4)
Released:
- Fixed the bug
- Segment module didn't display the zero number.
- Modified the typo and UI.
May 31, 2019 (v0.1.3)
Released:
- Fixed the bug
- Project was empty when new project without board select.
- Added the library
- Servo motor
May 29, 2019 (v0.1.2)
Released:
- Fixed the bug
- Tooltip didn't disappear sometimes.
- Added the library
- Gyroscope Module (MPU6050)
May 17, 2019 (v0.1.1)
Released:
- Fixed the bug
- Error occurred when compile the dot-matrix module.
May 17, 2019 (v0.1.0)
Released:
- Beta version
