ZZZ_doubleResolution.h
this is code that can double resolution. you will want to change area that gets numbers from main memory. the output of a higher resolution cell is float temp=DoubleResolutionValue(x, y) and result is stored in temp. it is cached and manages hit and miss as well
h -
4.19 kB -
09/03/2019 at 23:20
