Step 11
- Unhide the Foundation
- Select two Objects
- Choose Stitch & Scoop Tool and in drop-down select Object to cut out
- Click Apply'
Step 12
- Select Cylinder Shape
- Top and Bottom Radius set to 15
- Height to 50
- Vertical Segments to 64
Step 13
- Choose Cube shape
- Turn Off "Hide All Objects"
- Turn On Wireframe
- Width set to 15
- Height to 8
- And Depth to 50
Step 14
- Firstly let's rename our lamp Object to "Lamp"
- Then select Port and perform Align Utilite
- In reference drop-down select "Lamp"
- Align set to Bottom-Back
- And Offset to 40 by Z and 3 by Y
Step 15
- Choose Box Shape
- Depth set to 7
- Then click Finalize
Step 16
- Select Jumper
- Open Align Utilite
- In reference drop-down select Port
- Offset set to 10 by Z
Step 17
- Select Jumper
- Open Copy Offsets
- Z set to 10
- Click Copy
- After that open Move tool and set Y to 0
Step 18
- Select Foundation
- Click Reverse Selection
- Open Stitch & Scoop
- Click on Button - Union
Step 19
- Select All with Ctrl+A
- Select Option Difference
- In drop-down select Object with name "union_1"
- Then click Apply
Step 20
- Open Shape Generator
- Turn Off "Hide all objects"
- Set Top and Bottom radius to 28
- Number of Edges set to 64
- Height set to 10
