Step 1
- Select Shape Generator
- Set number of edges to 64
- Radius to 45 and height to 50
- Then click plus button to add new Segment
Step 2
- Now set only Top Radius to 40
- Add another segment with Top Radius 30
- And the last Segment with Top Radius 25 and Height 20
Step 3
- Switch view to Top and Orthographic mode
- Choose Free Hand tool
- Select Spline Brush
- Set Smoothness to 10 and height to 50
- Then start drawing random molds
Step 4
- Switch back to Perspective mode
- Rotate molds by Y and X to 90
Step 5
- Choose Bend Tool, Origin set to Middle and Z to -50
- Now we need to rotate it by Z to 90 again
Step 6
- Choose Move Tool and set X to 0
- Choose Scale Tool and in Advanced Settings turn on "Keep Proportion" and set X to 65
- Select Move Tool and set Z to 30
Step 7
- Open Scale Tool again and set Y to 60
- Then Choose Move tool and set Y to 55
Step 8
- Select Copy Offsets Tool and set Y to 50 and Z to -5
- Then select two Objects and perform Copy Offsets with option Pivot and Number Of Copies – 3
Step 9
- Select Foundation and open Copy Offsets
- Pivot change to Position and Number of Copies - 1
- Click Copy
- Then Hide the selected Foundation using Settings Button on the right
Step 10
- Move camera under model and select Bottom Polygons with Right Mouse Button
- Then select Move Tool and set Y to 50
- Select exactly the Foundation copy
- Then open Scale Tool and set X and Z to 80
