Queen Bee pin badge
Charming blinky Bee badge
Starting from
has orders / reviews
Ships from
This is a wearable , pin it wherever you want, use it as ornament or make it a great gift.
I realized that The Queen Bee badge could be use to improve your skills & get fun assembling it.
It could "bee" a challenge!I have not drawing skills so this is a great succes , i like the way was done.
You can see some sketches until the final design.
Design
I started drawing the character on paper then imported to inkscape.
Autodesk Fusion 360 was helpful to get the PCB outline.
Queen Bee progress
Drawing sketch / capture / progress / Inkscape / Final design
Electronics
The circuit was captured on Autodesk EAGLE, this is based on low power & low pin count mcu, a pic10LF322.
This mcu has 4 GPIOS , 1 of them is just input.
•Operation Voltage 1.8V – 3.6V
•Up to 512 Words of Flash Program Memory
• 64 Bytes Data Memory
The electronics is powered by a  cr1220/25 battery so this has to be power saving.
Schematic
Qeen Bee Sch / Autodesk EAGLE
PCBee
PCB top & bottom layers / Autodesk Eagle
Manufacturing
I send to manufacture 2 versions of this board , one with HASL finish and the other one with ENIG finish , both came out gorgeous .
When you prototype with Seeed Fusion, they can definitely provide Free DFA and Free functional tests for you! Check out their website to know about their manufacturing capabilities and service.
Function
The LEDs are controlled by charlieplexing technique ,so 1 LED is running at time,this POV feature save power and works great with low pin count mcu.
The Queen Bee badge stills sleep  in low power mode until you wake her up pressing the push button.
Pressing the button will change the LEDs animation until go to sleep again.
Aesthetics
  • Use this as a Pin or on Necklace
  • The PCB has ENIG finish , this gives to our Queen a real Golden Crown.
  • Black silkscreen on whithe soldermask
  • Light weight, so the pcb thickness is 0.8mm
  • Small size, 30 x 35mm
  • PCB was used as a light diffuser
Assembling - The fun part :D
  • On top there's just two LED s, I select yellow color for the eyes to not blind.
  • On backside you can find 4 LEDs reverse mounted, this is to get a light effect ,looks cool.
  • The components were distribuited to ease the soldering and optimize the space.
  • I think the hardest part to solder is the mcu,it's a sot23-6 package,nothing special :P
Queen Bee Front & Bottom view
Component location , Top & bottom view
A video or pictures hand assembling will be here
Tools required :
  • Soldering iron / pliers / solder wire / flux
Where will it be sold?
Working
  • 1 × pic10LF322 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 6 × LED Fiber Optics / Emitters
  • 3 × resistor 10 ohm smd 0805 package
  • 1 × capacitor 1uF ceramic capacitor 0805 package
  • 1 × push button smd switch
View all 8 components
  • 1
    Step 1
View all instructions
