The picture is not all that awesome. It's the obligatory "hello" program.
What's cool is that it's running on a Tronxy/Chitu main board with a stock bootloader, meaning that you don't need ST-links, the STM32CubeProgrammer, or anything else to flash it. And if you don't like it, you can always go back.
J.C. Nelson
Amazing work! Nice to see that the base work was done and that it might be an option to change the firmware instead of the whole board. Thanks!
