The picture is not all that awesome. It's the obligatory "hello" program.
What's cool is that it's running on a Tronxy/Chitu main board with a stock bootloader, meaning that you don't need ST-links, the STM32CubeProgrammer, or anything else to flash it. And if you don't like it, you can always go back.
![](https://cdn.hackaday.io/images/2855501569354346842.jpg)
Amazing work! Nice to see that the base work was done and that it might be an option to change the firmware instead of the whole board. Thanks!
