AP62200WU
A project log for Raspberry Pi EVSE Hat
Use a Raspberry Pi to build an EV charging station
nick-sayerNick Sayer • 02/28/2022 at 01:21•0 Comments
I tried this chip out on another project, and one thing I discovered is that the absolute maximum voltage on the EN pin is 6 volts. That means you can't just tie it to Vin. Fortunately, the spec sheet does say you can leave it floating and it will be pulled up, so it's not a huge inconvenience. But it does mean that I have to get new boards in before I can add inventory back to the store.
