342 days later .... Magics of Kaitai Struct
10/10/2019 at 13:12 • 0 commentsDue to some personal circumstances and then to the COVID-19 confinement, I didn't find the time to work effectively on Tsukuyomi and also to update the project logs.
Nevertheless in the past log I've reached a good milestone in understanding the Lunii image format, which lead me to: "I have to create python script to parse the Lunii images contents".
Then thanks to a HAM Radio Project I discovered the Holy Graal of binary parsing: Kaitai Struct.
Before starting this log It worth noting that thanks to a message in the Public Chat I came a cross an other project https://github.com/marian-m12l/studio that build a complete and advanced application written in JAVA to update Lunii through the USB. Unfortunately I didn't succeed yet to use it but the project seems to contains valuable information about the format of Lunii Image, things that I'm intending to take off if I'm blocked somewhere.
1. Falling in Love with Kaitai Struct
Kaitai Struct basically defines a declarative language to describe binary data structures within a .ksy file and then compile it into source files of your preferred programming languages.
$ ksc --target python kaitai-struct/lunii.ksv
So after playing with Kaitai Struct in this powerful online IDE using some small portions of Lunii image dumps and also locally with Kaitai Struct Compiler (KSC) and Kaitai Struct Vsualizer (KSV) by using the whole Lunii image dump, I construct iteratively a first description of Lunii image format in Kaitai Struct Language lunii.ksy , that consist of 3 principal structures: content_struct, story_struct and node_struct. It also import Kaitai Struct definitions of Bitmap and Wav files that I copied from Kaitai Struct Formats Library repository that host a wonderful amount of format description in Kaitai Struct Language.
a. content_struct
In Lunii image I found out that the content from 0 up the offset 0x030D_4000 contains no useful information beside the version and some system medias (Battery, Error, USB ...) So I decided to ignore it and just call it Header.
meta: id: lunii file-extension: lunii endian: be imports: - bmp - wav seq: - id: header size: fileoffset - id: contents type: content_struct instances: fileoffset: value: 0x30D4000
Starting from 0x030D_4000 address useful things start: the definition of the content especially the value of number of stories and stories information (start_address and size).
content_struct: seq: - id: nbr_stories type: u2 - id: stories type: story_struct repeat: expr repeat-expr: nbr_stories
b. story_struct
Stories information contains the start address and size values in Sector unit (512 Bytes) next to value that I have to figure out but I called it unknown
In order to calculate more easily a precise address of the story fields (needed more further), I had to reference the absolute location of the start address in special variable called abs_start_address.
story_struct: seq: - id: start_address type: u4 - id: size type: u4 - id: unknown type: u4 instances: abs_start_address: value: _root.fileoffset + (start_address * 0x200) story_info: pos: abs_start_address type: story_info_struct
So the story_info_struct define a story by a number of nodes, a boolean (that I believe refers to factory_disabled), a uint16_t for the version of the story., and after some zeros story nodes start.
A node is a story media storage unit, that contains the data for the Bitmap and/or the Audio Wav.
story_info_struct: seq: - id: nbr_nodes type: u2 - id: factory_disabled type: u1 - id: version type: u2 - id: padding size: 0x200 - 5 #TODO this must be reworked - id: nodes type: node_struct repeat: expr repeat-expr: nbr_nodes
c. node_struct
The node struct contains the start addresses and sizes of the media in addition to a structure that I called navigation_struct which I believe it holds information about navigation and transition from one node to another.
node_struct: seq: - id: uuid size: 16 - id: image_start_sector type: u4 - id: image_size type: u4 - id: audio_start_sector type: u4 - id: audio_size type: u4 - id: navigation type: navigation_struct size: 0x200 - 32 instances: ##### this is just for debugging story_start_address: value: _parent._parent.abs_start_address image_start_address: value: story_start_address + ((1 + image_start_sector) * 0x200) audio_start_address: value: story_start_address + ((1 + audio_start_sector) * 0x200) ##### image: type: bmp pos: image_start_address size: image_size * 0x200 if: image_size != 0xffffffff audio: type: wav pos: audio_start_address size: audio_size * 0x200 if: audio_size != 0xffffffff image_raw: pos: image_start_address size: image_size * 0x200 if: image_size != 0xffffffff audio_raw: pos: audio_start_address size: audio_size * 0x200 if: audio_size != 0xffffffff
The complete KSY file is stored in the github repository of the project: https://github.com/danksz/tsukuyomi
d. Visualization
As said before KSV is very handy tool to visualize the format description applied to the binary image.
$ ksv Lunii.img lunii.ksy
The only inconvenience with KSV is that it takes a very longtime to parse Lunii Image (8 GB) and also require a lot of RAM. so killing chrome/firefox before may help ;)
So after checking with KSV that the KSY definition works great for one or two nodes and for the same for stories, I compiled it in a python module: lunii.py
2. The Parser and The Explorer
Developing python parser of Lunii image was very straightforward: sd-lunii-parser.py after generating the lunii.py module.
The parser will display the whole structure of Lunii Image and where medias (Bitmap and Wav sounds) are stored.
$ ./sd-lunii-parser.py ../dump/Lunii.img position of content structure: 51200000 position of number of stories: 51200062 Number of stories: 5 Story[00] address: 0x030D4200 size: 0x2BFDC800 sector: 0x00000001 nbr_nodes: 168 node[000] audio addr: 0x03A9E800 size: 187904 object: <wav.Wav object at 0x7f53d86a9be0> image addr: 0x30EE000 size: 230912 object: <bmp.Bmp object at 0x7f53d86a9e48> node[001] audio addr: 0x03ACC600 size: 255488 object: <wav.Wav object at 0x7f53d86a9f60> image addr: 0x3126600 size: 230912 object: <bmp.Bmp object at 0x7f53d86b0208> node[002] audio addr: 0x03B0AC00 size: 199680 object: <wav.Wav object at 0x7f53d86b0320> image addr: 0x200030D4200 size: 2199023255040 object: None [..]
The most exciting thing in Kaitai Struct is that it comes with a lot of other tools and libraries beside KSC , KSV, Kaitai Struct Format Library. Example: KaitaiFS that makes possible to mount in FUSE a filesystem while providing only the generated python module:
$ python3 -m kaitaifs.generic lunii Lunii.img mountpoint
So after mounting the image I can then use a file browser to explore the storage-media like exploring an USB or SDcard drive formated with FAT32 filesystem.
I've also successfully opened the audio files in a media player (ex: VLC).
The Extractor and the Combiner
Just like sd-lunii-parser.py script, creating additional python scripts that use the generated lunii.py module, is very easy.
The sd-lunii-extract-stories.py parse Lunii image and extract all founded stories into a folder named out-extract
Number of stories: 5 Story[00] address: 0x030D4200 size: 0x2BFDC800 sector: 0x00000001 nbr_nodes: 168 Story[01] address: 0x2F0B0A00 size: 0x0B7A7C00 sector: 0x0015FEE5 nbr_nodes: 019 Story[02] address: 0x3A858600 size: 0x08445A00 sector: 0x001BBC23 nbr_nodes: 199 Story[03] address: 0x42C9E000 size: 0x08BDFA00 sector: 0x001FDE50 nbr_nodes: 019 Story[04] address: 0x4B87DA00 size: 0x14FBB200 sector: 0x00243D4D nbr_nodes: 055 Extracting story n:0 to out-extract/Lunii-story0.lunii Extracting story n:1 to out-extract/Lunii-story1.lunii Extracting story n:2 to out-extract/Lunii-story2.lunii Extracting story n:3 to out-extract/Lunii-story3.lunii Extracting story n:4 to out-extract/Lunii-story4.lunii
Unfortunately Kaitai Struct currently support only reading binary (Writing it seems to be supported only in a development branch and for JAVA only). But thanks to some references I've put already in the KSY file I can **at least** add some extracted stories from a Lunii image to another Lunii Image.
So I had only to reconstruct manually the content structure as in sd-lunii-concat-stories.py :
nbr_stories_bin = nbr_stories.to_bytes(2, byteorder='big',signed=False) stories_struct_bin = b"" for pos, size in added_stories: pos -= fileoffset pos //= 0x200 size //= 0x200 unknown = 0 pos_bin = pos.to_bytes(4, byteorder='big',signed=False) size_bin = size.to_bytes(4, byteorder='big',signed=False) unknown_bin = unknown.to_bytes(4, byteorder='big',signed=False) stories_struct_bin += pos_bin + size_bin + unknown_bin content_bin = nbr_stories_bin + stories_struct_bin bfile.seek(fileoffset) bfile.write(content_bin)
Thus sd-lunii-concat-stories.py can generate a new Lunii Image which contains both original and already extracted stories:
$ ./sd-lunii-concat-stories.py ../../dumps/Adam_Lunii.img out-extract2 Number of stories: 5 Story[00] address: 0x030D4200 size: 0x2BFDC800 sector: 0x00000001 nbr_nodes: 168 Story[01] address: 0x2F0B0A00 size: 0x0B7A7C00 sector: 0x0015FEE5 nbr_nodes: 019 Story[02] address: 0x3A858600 size: 0x08445A00 sector: 0x001BBC23 nbr_nodes: 199 Story[03] address: 0x42C9E000 size: 0x08BDFA00 sector: 0x001FDE50 nbr_nodes: 019 Story[04] address: 0x4B87DA00 size: 0x14FBB200 sector: 0x00243D4D nbr_nodes: 055 Copy base image to out/Adam_Lunii.img-mod.img Adding Alice_Lunii-story1.lunii at 0x60838C00 Adding Alice_Lunii-story3.lunii at 0x6BFE0800 Adding Alice_Lunii-story4.lunii at 0x74BC0200 Adding Fred_Lunii-story1.lunii at 0x89B7B400 Adding Fred_Lunii-story2.lunii at 0x94DA4C00 Adding Fred_Lunii-story3.lunii at 0x9CDF4800 Adding Fred_Lunii-story4.lunii at 0xB3EBCC00
Let's now execute the parser script to check if sd-lunii-concat-stories.py generated a correct Lunii Image:
$ ./sd-lunii-parser.py out/Adam_Lunii.img-mod.img position of content structure: 51200000 position of number of stories: 51200146 Number of stories: 12 Story[00] address: 0x030D4200 size: 0x2BFDC800 sector: 0x00000001 nbr_nodes: 168 node[000] audio addr: 0x03A9E800 size: 187904 object: <wav.Wav object at 0x7fbc803f5dd8> image addr: 0x30EE000 size: 230912 object: <bmp.Bmp object at 0x7fbc803fc080> node[001] audio addr: 0x03ACC600 size: 255488 object: <wav.Wav object at 0x7fbc803fc198> image addr: 0x3126600 size: 230912 object: <bmp.Bmp object at 0x7fbc803fc400> [..] Story[05] address: 0x60838C00 size: 0x0B7A7C00 sector: 0x002EBB26 nbr_nodes: 019 node[000] audio addr: 0x60A38400 size: 133120 object: <wav.wav object="" at="" 0x7fcb2b967f60=""> image addr: 0x6083CE00 size: 230912 object: <bmp.bmp object="" at="" 0x7fcadeae71d0=""> node[001] audio addr: 0x60A58C00 size: 202240</bmp.bmp></wav.wav> [..]
Coooool!! the number of stories indeed was increased to 12 instead of 5. and new stories appears !!!
And the more important check: After writing the new Lunii Image to the sdcard of Lunii, all stories (old and new ones) was loaded SUCCESSFULLY!!!!
Next Steps
Try to understand the Navigation/Transition format to build a new story.
Days 3,4,5: Eureka, sound and images found!
10/04/2019 at 09:49 • 1 comment1. Toolchain not found
After stepping away few days far from my PC for family reason, I resumed my activities on the Tsykuyomi project.
So I started by reading the https://github.com/WHhkwong/SIPI_Bear_playback code and looking for a SNC7001A Toolchain/SDK to build it. But unfortunately the only website that propose it for download is login/password protected.So I turned to the SDCard dump meanwhile finding a way to get the toolchain.
2. Uninteresting hidden fat12 partition
I started by opening the dump with 'testdisk' utility to look for a hidden partition or disk structure. so I found only one "fat12" partition at address 0xD920 0000 :
D920 0000: EB 3C 90 4D 53 44 4F 53 35 2E 30 00 02 08 08 00 .<.MSDOS 5.0..... D920 0010: 02 00 02 00 50 F8 08 00 3F 00 FF 00 00 00 00 00 ....P... ?....... D920 0020: 00 00 00 00 80 01 29 22 8E 62 BC 4E 4F 20 4E 41 ......)" .b.NO NA D920 0030: 4D 45 20 20 20 20 46 41 54 31 32 20 20 20 33 C9 ME FA T12 3. D920 0040: 8E D1 BC F0 7B 8E D9 B8 00 20 8E C0 FC BD 00 7C ....{... . .....|
And more further I found the content of uninteresting files (pdf, link, ...) which appears anyway in the virtual storage media disk when I connect Lunii to the PC.
3. Comparing the dumps
So by analyzing the dumps of the sdcard before and after adding a new "Story" to Lunii -Thanks to vbindiff- , I found out very interesting things:
1. Bitmap Image files with "BM8" or "BM6" magic at specific addresses
$ hexdump -C disk-dump-0| grep -e BM6 -e BM8 00000600 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 00038c00 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 00071200 42 4d 36 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM6.......6...(.| 000a9800 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 030ee000 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 03126600 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 0315ec00 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 03197200 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 031cf800 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 03207e00 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 03240400 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 03278a00 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 032b1000 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 032e9600 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 03321c00 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 0335a200 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(.| 03392800 42 4d 38 84 03 00 00 00 00 00 36 00 00 00 28 00 |BM8.......6...(. ...
2. WAV files with "RIFF" magic
$ hexdump -C disk-dump-0 | grep RIFF 03a9e800 52 49 46 46 6e dd 02 00 57 41 56 45 66 6d 74 20 |RIFFn...WAVEfmt | 03acc600 52 49 46 46 6c e5 03 00 57 41 56 45 66 6d 74 20 |RIFFl...WAVEfmt | 03b0ac00 52 49 46 46 7c 0b 03 00 57 41 56 45 66 6d 74 20 |RIFF|...WAVEfmt | 03b3b800 52 49 46 46 46 51 02 00 57 41 56 45 66 6d 74 20 |RIFFFQ..WAVEfmt | 03b60a00 52 49 46 46 a6 19 02 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 03b82400 52 49 46 46 b4 2c 02 00 57 41 56 45 66 6d 74 20 |RIFF.,..WAVEfmt | 03ba5200 52 49 46 46 82 09 02 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 03bc5c00 52 49 46 46 20 10 01 00 57 41 56 45 66 6d 74 20 |RIFF ...WAVEfmt | 03bd6e00 52 49 46 46 26 5e 01 00 57 41 56 45 66 6d 74 20 |RIFF&^..WAVEfmt | 03bece00 52 49 46 46 c2 98 01 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 03c06800 52 49 46 46 26 90 01 00 57 41 56 45 66 6d 74 20 |RIFF&...WAVEfmt | 03c1fa00 52 49 46 46 26 13 01 00 57 41 56 45 66 6d 74 20 |RIFF&...WAVEfmt | 03c30e00 52 49 46 46 ce 28 b0 00 57 41 56 45 66 6d 74 20 |RIFF.(..WAVEfmt | 04733800 52 49 46 46 8c 27 be 00 57 41 56 45 66 6d 74 20 |RIFF.'..WAVEfmt | 05316000 52 49 46 46 a6 1f 01 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 05328000 52 49 46 46 f0 23 f9 00 57 41 56 45 66 6d 74 20 |RIFF.#..WAVEfmt | 062ba400 52 49 46 46 be 09 cc 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 06f7ae00 52 49 46 46 e6 89 01 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 06f93800 52 49 46 46 26 45 01 00 57 41 56 45 66 6d 74 20 |RIFF&E..WAVEfmt | 06fa7e00 52 49 46 46 4a 15 e7 00 57 41 56 45 66 6d 74 20 |RIFFJ...WAVEfmt | 07e19400 52 49 46 46 4e ea d1 00 57 41 56 45 66 6d 74 20 |RIFFN...WAVEfmt | 08b38000 52 49 46 46 7a 7f 01 00 57 41 56 45 66 6d 74 20 |RIFFz...WAVEfmt | 08b50000 52 49 46 46 0e 91 c8 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 097d9200 52 49 46 46 9e e3 9b 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 0a197600 52 49 46 46 26 90 01 00 57 41 56 45 66 6d 74 20 |RIFF&...WAVEfmt | 0a1b0800 52 49 46 46 60 58 01 00 57 41 56 45 66 6d 74 20 |RIFF`X..WAVEfmt | 0a1c6200 52 49 46 46 1c b3 be 00 57 41 56 45 66 6d 74 20 |RIFF....WAVEfmt | 0adb1600 52 49 46 46 5c 1a 12 01 57 41 56 45 66 6d 74 20 |RIFF\...WAVEfmt | 0bed3200 52 49 46 46 2a 6d 01 00 57 41 56 45 66 6d 74 20 |RIFF*m..WAVEfmt | 0beea000 52 49 46 46 ce 4f 93 00 57 41 56 45 66 6d 74 20 |RIFF.O..WAVEfmt | 0c81f000 52 49 46 46 3e 45 28 01 57 41 56 45 66 6d 74 20 |RIFF>E(.WAVEfmt | ...
3. Global structure about number, start addresses and length of Lunii Stories
030D4000 # Address of info structure 00 02 00 ===> number of album 00 00 01 00 ===> Start sector of the first Story 15 FE E4 00 ===> length in sector of the first Story 00 00 00 00 ===> id of first Story ??? 15 FE E5 00 ===> Start sector of the second Story 08 59 F6 00 ===> length in sector of the second Story A8 00 00 00 ===> id of second Story ??? ...
4. Other Information which I believe that belong for navigation:
030D4200 00 A8 01 030D4400 C4 13 9D .. C3 00 00 .. A9 00 01 00 00 FF FF FF FF FF FF 00 01 00 01 030D4600 3D 7C 6F .. C3 00 00 .. A9 00 24 00 00 FF FF FF FF FF FF 00 00 00 01 030D4800 34 94 4D .. FF 00 00 .. AA 00 02 00 00 FF FF FF FF FF FF 00 00 00 01 00 01 00 00 00 01 00 00 030D4A00 8C 2C A1 .. FF 00 00 .. AB 00 04 00 00 00 A9 00 24 00 00 00 00 00 01 00 01 00 00 00 01 00 00 030D4E00 C9 64 6C .. C3 00 00 .. A9 00 24 00 01 FF FF FF FF FF FF 00 01 00 01 00 01 00 00 00 00 00 00 .... 030E9200 fd c7 f2 .. c3 00 15 .. cd 00 30 00 2f 00 a9 00 24 00 00 00 01 00 01 00 01 00 00 00 00 00 00
Next Steps:
1. Write a python script that extract medias (wav + BM + navigation data?? ) from a dump.
2. Understand the navigation data.
3. Construct a new "Story" with simple contents bitmap and sound for : the simplest is digits : 0 1 2 3 4 5 6 7 8 9 and try to pushed write it into the SDCard.
Day2: more exploration ...
09/24/2019 at 17:23 • 0 comments1. Datasheet.
So thanks to the datasheet, we know now that Lunii chipset is based on a 16bit DSP core and I also found out that the 10 pts connector is belonging to ICE-Debug (very known in the arduino/avr world) and not for UART or SWD.
Unfortunately I don't have an ICE-Debug probe. Maybe I have to consider to buy one if I'm stuck.
On the other hand according to the chip pinout, the UART seems to be on p4.10 and p4.11 lines which I have to trace to see if I can still hook through a Logic Analyzer.
2. Googling
Some googling about the chip name lead me to an interesting paper about reverse engineering a toy called "Teddy Ruxpin" which it is based on the same Sonix chip SNC7001A.
The paper contains useful information about the proprietary audio format "AU".
@Frederic Renet who just joined the project point me also to an interesting code in github that contains code which we believe it for the SNC7001A firmware. But we don't know how we can build/flash it.
3. SDCard Dump
I successfully dumped the SDCard (I will upload the dump somewhere tomorrow). The size of the dump is 8G. but I found useful raw data only starting from address 0x03ad2000
$ hexdump -C lunii.dump 03ad2000 05 00 07 00 0a 00 04 00 fb ff f4 ff 00 00 03 00 |................| 03ad2010 ff ff 09 00 08 00 03 00 0c 00 04 00 fe ff fc ff |................| 03ad2020 ff ff 11 00 06 00 01 00 fd ff 00 00 01 00 0a 00 |................| 03ad2030 18 00 0b 00 11 00 12 00 12 00 05 00 ff ff f7 ff |................| 03ad2040 17 00 0f 00 13 00 13 00 06 00 03 00 16 00 21 00 |..............!.| 03ad2050 24 00 11 00 f9 ff 0f 00 f4 ff ec ff 18 00 03 00 |$...............| 03ad2060 ed ff df ff 2c 00 29 00 00 00 09 00 02 00 e8 ff |....,.).........
Next Steps
1. Looking for SNC7001A Toolchain/SDK.
2. Try to find the UART.
3. Try to buy a ICE-Debug.
4. Learn more about Sonix proprietary audio format.
5. Analyze more deeply the sdcard dump.
Day1: exploring ...
09/23/2019 at 15:48 • 3 commentsI started the project by just exploring the Lunii box physically and connect it to a Linux workstation. so I noticed the following:
1. When the box usb is plugged into a linux system, lsusb and dmesg gives :
$ lsusb ... Bus 001 Device 016: ID 0c45:6820 Microdia ...
And a media storage is also appearing:
$ dmesg | tail -30
$ dmesg | tail -30 ... 667105.143680] usb 1-2: new high-speed USB device number 17 using xhci_hcd [667105.616668] usb 1-2: New USB device found, idVendor=0c45, idProduct=6820 [667105.616671] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=1 [667105.616674] usb 1-2: Product: USB2.0 DSP [667105.616676] usb 1-2: SerialNumber: USB2.0 DSP [667105.618045] usb-storage 1-2:1.0: USB Mass Storage device detected [667105.618551] scsi host4: usb-storage 1-2:1.0 [667106.628045] scsi 4:0:0:0: Direct-Access SONiX SNC7001A USBDisk 0.01 PQ: 0 ANSI: 0 CCS [667106.628239] sd 4:0:0:0: Attached scsi generic sg3 type 0 [667106.628770] sd 4:0:0:0: [sdd] 20480 512-byte logical blocks: (10.5 MB/10.0 MiB) [667106.629015] sd 4:0:0:0: [sdd] Write Protect is off [667106.629016] sd 4:0:0:0: [sdd] Mode Sense: 03 00 00 00 [667106.629268] sd 4:0:0:0: [sdd] No Caching mode page found [667106.629270] sd 4:0:0:0: [sdd] Assuming drive cache: write through [667106.634987] sdd: [667106.636788] sd 4:0:0:0: [sdd] Attached SCSI removable disk
2. After unboxing Lunii, the chipset/SoC appears to be an obscure Chinese chip called Sonix. But unfortunately the exact part number cannot be read. It was maybe intentionally obfuscated.
Thanks to dmesg (see above) we know that the SoC is a Sonix SNC7001A. And a datasheet can be found here: here3. In the PCB we can identify an SDCard (surrounded in red in picture below). But it seems to be soldered to the PCB, because it's not eject-able.
We can also identify a 10pts connector (surrounded in green in picture below) that I hope it can handle signals to UART and SWD.
Next Steps- Extract the SDCARD and analyze its content
- Hook a digital analyzer on the 10pts connector to probe UART.
- Read the datasheet.
