The project is pretty forward. The "RUN" buttons are wired to pins 3 (LEFT) and 4 (RIGHT) of the controller port and the "JUMP/THROW" button is wired to pin 6 (FIRE). All buttons return to pin 8 (GROUND).
Few components are required: Three buttons, one cable and one box.
The buttons used on this project have low profile
The low profile buttons allowed to use a low profile box.
The buttons were disposed like the original track and field controller
The unused wires are isolated using heat shrink tubing
And here's the finished controller.
Solderking
Evo
goathens
Do you by any chance have the Link/files for the Plastic case/box?
Also how are you finding those buttons? If they are great, can you please share their part number as well so I can get something which you have tested.
