I messed up :(
A project log for Internal USB 2 hub with header pins
Internal USB 2 hub
steverddrfsteverddrf • 10/14/2019 at 23:59•0 Comments
The mk2 pcb's work ok but they have issues such as that they will not fit most motherboards due to there being no standard for where the motherboard ports are placed, the external power was fed through a 1 amp diode, and I forgot to do the Impedance of the differential tracks :(
Back to the drawing board for the mk3 pcb and higher power diodes are on order, watch this space :)
